Tsurugi Posted July 27, 2011 Posted July 27, 2011 Hi hi try to instal lion 10.7 Gm from usb method MaldoN i launch bootloader the system load ...5 minutes and break to write "still waiting for root device" i have burn in usb my dsdt.aml in Extra folder and driver patched for my video "gtx 560 ti" in /S/L/E and use this flag for "pci configuration error" ... npci=0x2000 help me
Administrators MaLd0n Posted July 27, 2011 Administrators Posted July 27, 2011 Mobo and Chipset? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Tsurugi Posted July 27, 2011 Author Posted July 27, 2011 Hi MaldoN my mobo is msi p35 neo 2 (you have send me dsdt.aml yesterday remember) ? chipset sata Intel ICH9R AHCI work i have snow 10.6.8 work good i don't understand I do not know what to feel more
Tsurugi Posted July 28, 2011 Author Posted July 28, 2011 for the moment solved in this mode .... install easyinstall from multiboot and install pci efi 10.6 and update to 10.7 ...... install start
Tsurugi Posted July 28, 2011 Author Posted July 28, 2011 ok install good ... after reboot from hd "don't recognize ps2 keyboard" i'm search and try 2 kext but does't work arghhhhhhhhhhhhhhhhhh !!!
Tsurugi Posted July 28, 2011 Author Posted July 28, 2011 ok install good ... after reboot from hd "don't recognize ps2 keyboard" i'm search and try 2 kext but does't work arghhhhhhhhhhhhhhhhhh !!! ok fix keyboard problem ..... Lion start correctly
Tsurugi Posted July 28, 2011 Author Posted July 28, 2011 only boot from usb if tyry boot on hd waitinf for DSMOS and don't start i have installed multishit 3.8.0' "easy install, chimera and system utility" don't boot from hd
Administrators MaLd0n Posted July 28, 2011 Administrators Posted July 28, 2011 dont use multishit use Extra folder topic and Chameleon -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Tsurugi Posted July 28, 2011 Author Posted July 28, 2011 is the first thing I tried ...... but still same result
Tsurugi Posted July 28, 2011 Author Posted July 28, 2011 i'm reistall bootloader, and extra, and my dsdt ........ no result change boot only usb
Administrators MaLd0n Posted July 28, 2011 Administrators Posted July 28, 2011 i'm reistall bootloader, and extra, and my dsdt ........ no result change boot only usb use NULLCPUPM in S/L/E try it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Tsurugi Posted July 28, 2011 Author Posted July 28, 2011 is in your topic .... just have try .... no result change
Tsurugi Posted July 28, 2011 Author Posted July 28, 2011 have reformat hd and reinstall all lion install - reboot goto on leopard and modify "setup assistant" in lion (my keyboard is ps2) - reboot from usb to hd configure sysytem - copy extra folder (mac 3.1) - copy my dsdt.aml in extra folder - install chameleon - install nullcpupm - repair perm rebuild cache - reboot ..... and
Administrators MaLd0n Posted July 28, 2011 Administrators Posted July 28, 2011 very strange I have no idea -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Tsurugi Posted July 28, 2011 Author Posted July 28, 2011 if possible my video card gtx 560 ti ? driver mod NVDAGF100Hal.kext insert in S/L/E ?
Administrators MaLd0n Posted July 28, 2011 Administrators Posted July 28, 2011 you need to test -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Tsurugi Posted July 28, 2011 Author Posted July 28, 2011 you need to test I'M TEST SAME RESULT when it reaches the point of writing "waiting for DSMOS" I hear the noise of the hard disk shuts down
Tsurugi Posted July 28, 2011 Author Posted July 28, 2011 if you don't have an idea ... i'm back to windows ...not solution for me
Administrators MaLd0n Posted July 28, 2011 Administrators Posted July 28, 2011 \õ/ Use Snow wait for solution Lion sucks at moment -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Tsurugi Posted July 28, 2011 Author Posted July 28, 2011 ahahaha:) hahah yes use snow but no video ...... gtx 560 ti not supported .....are unfortunate !!!!!!!!!!!!!!!!!!!! however, I thank you for all the help you gave me ....... Thanks for Everything
Tsurugi Posted July 29, 2011 Author Posted July 29, 2011 ahahaha:) hahah yes use snow but no video ...... gtx 560 ti not supported .....are unfortunate !!!!!!!!!!!!!!!!!!!! however, I thank you for all the help you gave me ....... Thanks for Everything in the last mement i have found a solution ...install IOahciblockingstorageinjector, fakesmac, IOPICIfamilifix, Nullcpupowermanagement, chimera 1.41.r877, generatecpustates and system start
