Help with booting from HDD after installed catalina
Hi guys
FINALLY installed Catalina from Olarila premade usb booter.
After install, i copy the EFI folder to the efi on my HDD,  im having an issue there,  Hdd will boot into system fine from USB i used to install, but Wont boot from the actuall HDD itself without the usb,  My EFI is straight from the usb as a copy,  Config is fine,  Kexts are fine,  but the error im getting is - - "ERROR allocating 0x321d pages at 0x0000000001031000 alloc type 2 Error loading kernel cache (0x9).   Boot failed: will sleep for 10 seconds before exiting..............."
Has anyone encountered this and what is the solution please??,  ive never had this problem installing Olarila images in the past,  i even had my previous efi backed up and have the same problem.
Please help me boot without the need for usb stick.
u need use last clover or opencore version and reset nvram one time
Thanks buddy,  Now booting,   only 1 issue left to solve,  and thats in the clover boot screen itself where i select the os to boot to i have now lost keyboard funcionality,  it is a USB wireless keyboard,  it was working previously when i couldnt get the system to boot, but with latest clover installed and working boot,  i cant alter anything at Clover bootscreen,  it is of course your configs im using still so all usb patches and that will be done already, maybe its a kext or something, any ideas what could cause this?,  once i reach the system and it loads up, USB then works,  but not at the clover boot screen.
