Hello everyone...................!
Resources:-
1:-Retail copy of Snow Leopard
2:- ModCD (having legacy kernel )
Pre-Installation
Make sure to have this settings on your BIOS:
Plug and Play OS: Yes.
USB Legacy: Yes.
USBSpeed : FullSpeed. (Just for installation)
Power Management -
Suspend Mode: S1 (POS) or S3
ACPI 2.0 Support: Enabled
ACPI APIC Support: Enabled
Installation
Install os x while customize do this
Disable EVERYTHING first !
Even the bootloader,
Leave just these options marked: ElliotLegacyRTC, EvOreboot, FakeSMC, NullCPUPowerManagement, NForceLan,NForceAta
After installation insert the mod cd and boot os x drive once you done install latest chameleon boot loader
After done update this
Install the combo update 10.6.8 don't restart install Legacy Kernel Update and copy kext to S/L/E and rebuilt cache using kext utility and done.....!
This the extra folder for ASUS M2N68 AM SE 2
working :-
1 sound (slightly cracking but working fine )
2 LAN
3 usb
4 Nvidia 94000GT 1GB
Extra.rar
HackBook Pro :-HP DV6-6121 TX (Win 10 Pro + macOS 10.13.6 + OC )
Hac Pro:-GA-B365-D3H, Core i5 9440F AMD RX 580 8 GB (Win 10 Pro + macOS 10.15.7 + Big Sur Beta )
Hac Pro:-z97 sabertooth mark 2, Core i7- i7 4790k with GT 740 2GB and 32 GB Ram (OC+Catalina)
iHack:- Assus M2N68-AM-SE2,AMD Athlon+LE-1640,250 SSD ,4GB DD3 800MHZ Nvidia 9400GT (win 10 and 10.9.5+10.10.5)
iHack:-GA875M-D3H ,core-i5 3250,NVDIA 610-2GB 27"LED,8GB DDR3 1600mhz, (Only 10.10.5+10.11.6 with CLOVER)
iHack:-GA-78LMT-S2PT ,AMD Phenom II-X2 560,Radeon 6770 1 GB ,onboard Radeon HD 3000 not tested 4 GB DDR-3 1333 MHZ (10.11.6+Win 10 pro) Special thanks....  To Genius donovan6000 For Mode Bios (WiFi +BT Whitelist removed) & Amazing Hackintosh Guides and tutorial and much more visit this blog Hackintosh Mumbai
