which olarilla image is best for my laptop ?with issue after installation fix please
CPU-Z TXT Report
Binaries
CPU-Z version            1.97.0.x64
Processors
CPU Groups            1
CPU Group 0            4 CPUs, mask=0xF
Number of sockets        1
Number of threads        4
APICs
Socket 0
    -- Core 0 (ID 0)
        -- Thread 0    0
        -- Thread 1    1
    -- Core 1 (ID 1)
        -- Thread 2    2
        -- Thread 3    3
Timers
    ACPI timer        3.580 MHz
    Perf timer        10.000 MHz
    Sys timer        1.000 KHz
Processors Information
Socket 1            ID = 0
    Number of cores        2 (max 2)
    Number of threads    4 (max 4)
    Manufacturer        GenuineIntel
    Name            Intel Core i5 5200U
    Codename        Broadwell-U
    Specification        Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz
    Package (platform ID)    Socket 1168 BGA (0x6)
    CPUID            6.D.4
    Extended CPUID        6.3D
    Core Stepping        E0/F0
    Technology        14 nm
    TDP Limit        15.0 Watts
    Tjmax            105.0 °C
    Core Speed        2499.4 MHz
    Multiplier x Bus Speed    25.0 x 100.0 MHz
    Base frequency (cores)    100.0 MHz
    Base frequency (ext.)    100.0 MHz
    Stock frequency        2200 MHz
    Instructions sets    MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
    Microcode Revision    0x2D
    L1 Data cache        2 x 32 KB (8-way, 64-byte line)
    L1 Instruction cache    2 x 32 KB (8-way, 64-byte line)
    L2 cache        2 x 256 KB (8-way, 64-byte line)
    L3 cache        3 MB (12-way, 64-byte line)
    Max CPUID level        00000014h
    Max CPUID ext. level    80000008h
    FID/VID Control        yes
    Turbo Mode        supported, enabled
    Max non-turbo ratio    22x
    Max turbo ratio        27x
    Max efficiency ratio    5x
    O/C bins        none
    Ratio 1 core        27x
    Ratio 2 cores        25x
    Ratio 3 cores        25x
    Ratio 4 cores        25x
    Ratio 5 cores        25x
    Ratio 6 cores        25x
    IA Voltage Mode        PCU adaptive
    IA Voltage Offset    0 mV
    GT Voltage Mode        PCU adaptive
    GT Voltage Offset    0 mV
    LLC/Ring Voltage Mode    PCU adaptive
    LLC/Ring Voltage Offset    0 mV
    Agent Voltage Mode    PCU adaptive
    Agent Voltage Offset    0 mV
    TDP Level        15.0 W @ 22x
    TDP Level        7.5 W @ 6x
    Temperature 0        70 degC (158 degF) (Package)
    Temperature 1        70 degC (158 degF) (Core #0)
    Temperature 2        67 degC (152 degF) (Core #1)
    Voltage 0        0.99 Volts (VID)
    Voltage 1        +0.00 Volts (IA Offset)
    Voltage 2        +0.00 Volts (GT Offset)
    Voltage 3        +0.00 Volts (LLC/Ring Offset)
    Voltage 4        +0.00 Volts (System Agent Offset)
    Power 00        9.91 W (Package)
    Power 01        7.62 W (IA Cores)
    Power 02        0.21 W (GT)
    Power 03        0.00 W (Uncore)
    Power 04        2.08 W (DRAM)
    Clock Speed 0        2499.42 MHz (Core #0)
    Clock Speed 1        2499.42 MHz (Core #1)
    Core 0 max ratio    27.0 (effective 25.0)
    Core 1 max ratio    27.0 (effective 25.0)
Thread dumps
CPU Thread 0
    APIC ID            0
    Topology        Processor ID 0, Core ID 0, Thread ID 0
    Cache descriptor    Level 1, D, 32 KB, 2 thread(s)
    Cache descriptor    Level 1, I, 32 KB, 2 thread(s)
    Cache descriptor    Level 2, U, 256 KB, 2 thread(s)
    Cache descriptor    Level 3, U, 3 MB, 16 thread(s)
    CPUID
    0x00000000        0x00000014    0x756E6547    0x6C65746E    0x49656E69
    0x00000001        0x000306D4    0x00100800    0x7FFAFBBF    0xBFEBFBFF
    0x00000002        0x76036301    0x00F0B5FF    0x00000000    0x00C30000
    0x00000003        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000004        0x1C004121    0x01C0003F    0x0000003F    0x00000000
    0x00000004        0x1C004122    0x01C0003F    0x0000003F    0x00000000
    0x00000004        0x1C004143    0x01C0003F    0x000001FF    0x00000000
    0x00000004        0x1C03C163    0x02C0003F    0x00000FFF    0x00000006
    0x00000005        0x00000040    0x00000040    0x00000003    0x11142120
    0x00000006        0x00000077    0x00000002    0x00000009    0x00000000
    0x00000007        0x00000000    0x021C27AB    0x00000000    0x9C000400
    0x00000008        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000009        0x00000000    0x00000000    0x00000000    0x00000000
    0x0000000A        0x07300403    0x00000000    0x00000000    0x00000603
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000000
    0x0000000B        0x00000004    0x00000004    0x00000201    0x00000000
    0x0000000C        0x00000000    0x00000001    0x00000001    0x00000000
    0x0000000D        0x00000007    0x00000340    0x00000340    0x00000000
    0x0000000D        0x00000001    0x00000000    0x00000000    0x00000000
    0x0000000D        0x00000100    0x00000240    0x00000000    0x00000000
    0x0000000E        0x00000000    0x00000000    0x00000000    0x00000000
    0x0000000F        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000010        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000011        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000012        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000013        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000014        0x00000000    0x00000001    0x00000001    0x00000000
    0x80000000        0x80000008    0x00000000    0x00000000    0x00000000
    0x80000001        0x00000000    0x00000000    0x00000121    0x2C100800
    0x80000002        0x65746E49    0x2952286C    0x726F4320    0x4D542865
    0x80000003        0x35692029    0x3032352D    0x43205530    0x40205550
    0x80000004        0x322E3220    0x7A484730    0x00000000    0x00000000
    0x80000005        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000006        0x00000000    0x00000000    0x01006040    0x00000000
    0x80000007        0x00000000    0x00000000    0x00000000    0x00000100
    0x80000008        0x00003027    0x00000000    0x00000000    0x00000000
    MSR 0x0000001B        0x00000000    0xFEE00900
    MSR 0x0000003A        0x00000000    0x00000005
    MSR 0x00000035        0x00000000    0x00020004
    MSR 0x000001A0        0x00000000    0x00850089
    MSR 0x000000CE        0x0005053B    0xF3011600
    MSR 0x00000017        0x00180000    0x00000000
    MSR 0x000000C1        0x00000000    0x00000000
    MSR 0x000000C2        0x00000000    0x00000000
    MSR 0x000000C3        0x00000000    0x00000000
    MSR 0x000000C4        0x00000000    0x00000000
    MSR 0x00000186        0x00000000    0x00000000
    MSR 0x00000187        0x00000000    0x00000000
    MSR 0x000001AD        0x00001919    0x1919191B
    MSR 0x00000194        0x00000000    0x00010000
    MSR 0x0000019A        0x00000000    0x00000000
    MSR 0x000001A4        0x00000000    0x00000000
    MSR 0x000001B1        0x00000000    0x88220800
    MSR 0x000001FC        0x00000000    0x0004005F
    MSR 0x00000606        0x00000000    0x000A0E03
    MSR 0x00000601        0x40101414    0x00000100
    MSR 0x00000610        0x804280C8    0x00DD8078
    MSR 0x00000611        0x00000000    0x04B4BF5D
    MSR 0x00000639        0x00000000    0x0383AD02
    MSR 0x00000641        0x00000000    0x00180703
    MSR 0x00000619        0x00000000    0x00EA69E3
    MSR 0x00000614        0x00000000    0x00000078
    MSR 0x00000648        0x00000000    0x00000016
    MSR 0x00000649        0x00000000    0x0006003C
    MSR 0x0000064A        0x00000000    0x00000000
    MSR 0x0000064B        0x00000000    0x00000000
    MSR 0x00000198        0x00001FA1    0x00001900
    MSR 0x00000199        0x00000000    0x00001600
CPU Thread 1
    APIC ID            1
    Topology        Processor ID 0, Core ID 0, Thread ID 1
    CPUID
    0x00000001        0x000306D4    0x01100800    0x7FFAFBBF    0xBFEBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000001
    0x0000000B        0x00000004    0x00000004    0x00000201    0x00000001
    MSR 0x0000001B        0x00000000    0xFEE00800
    MSR 0x00000611        0x00000000    0x04B4D117
    MSR 0x00000639        0x00000000    0x0383BAC8
    MSR 0x00000641        0x00000000    0x0018074E
    MSR 0x00000619        0x00000000    0x00EA6D19
CPU Thread 2
    APIC ID            2
    Topology        Processor ID 0, Core ID 1, Thread ID 0
    CPUID
    0x00000001        0x000306D4    0x02100800    0x7FFAFBBF    0xBFEBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000002
    0x0000000B        0x00000004    0x00000004    0x00000201    0x00000002
    MSR 0x000001B1        0x00000000    0x88240800
    MSR 0x00000611        0x00000000    0x04B4E224
    MSR 0x00000639        0x00000000    0x0383C805
    MSR 0x00000641        0x00000000    0x00180779
    MSR 0x00000619        0x00000000    0x00EA7037
    MSR 0x00000198        0x00001F8E    0x00001900
CPU Thread 3
    APIC ID            3
    Topology        Processor ID 0, Core ID 1, Thread ID 1
    CPUID
    0x00000001        0x000306D4    0x03100800    0x7FFAFBBF    0xBFEBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000003
    0x0000000B        0x00000004    0x00000004    0x00000201    0x00000003
    MSR 0x000001B1        0x00000000    0x88230800
    MSR 0x00000611        0x00000000    0x04B4F5B3
    MSR 0x00000639        0x00000000    0x0383D6D9
    MSR 0x00000641        0x00000000    0x001807CB
    MSR 0x00000619        0x00000000    0x00EA73DF
BIOS
UEFI                Yes
BIOS Date            12/06/05
Chipset
Northbridge            Intel Broadwell-U rev. 09
Southbridge            Intel Broadwell-U PCH L-P rev. 03
Bus Specification        PCI-Express 2.0 (5.0 GT/s)
Memory Type            DDR3
Memory Size            8 GBytes
Channels            Single
Memory Frequency        799.9 MHz (1:6)
CAS# latency (CL)        11.0
RAS# to CAS# delay (tRCD)    11
RAS# Precharge (tRP)        11
Cycle Time (tRAS)        28
Row Refresh Cycle Time (tRFC)    208
Command Rate (CR)        1T
Uncore Frequency        2399.4 MHz
Host Bridge            0x1604
Memory SPD
DIMM #                1
    SMBus address        0x50
    Memory type        DDR3L
    Module format        SO-DIMM
    Module Manufacturer(ID)    Micron Technology (2C00000000000000000000000000)
    Size            8192 MBytes
    Max bandwidth        PC3-12800 (800 MHz)
    Part number        16KTF1G64HZ-1G6E1
    Serial number        0E0E9E82
    Manufacturing date    Week 50/Year 14
    Number of banks        8
    Nominal Voltage        1.35 Volts
    EPP            no
    XMP            no
    AMP            no
JEDEC timings table        CL-tRCD-tRP-tRAS-tRC @ frequency
    JEDEC #1        5.0-5-5-14-19 @ 380 MHz
    JEDEC #2        6.0-6-6-16-22 @ 457 MHz
    JEDEC #3        7.0-7-7-19-26 @ 533 MHz
    JEDEC #4        8.0-8-8-22-30 @ 609 MHz
    JEDEC #5        9.0-9-9-24-33 @ 685 MHz
    JEDEC #6        10.0-10-10-27-37 @ 761 MHz
    JEDEC #7        11.0-11-11-28-39 @ 800 MHz
DIMM #                1
SPD registers
        00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
    00    92 11 0B 03 04 21 02 09 03 11 01 08 0A 00 FE 00
    10    69 78 69 30 69 11 18 81 20 08 3C 3C 00 F0 83 05
    20    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 00 00 00 00 00 00 00 00 0F 11 05 00
    40    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    50    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    60    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    70    00 00 00 00 00 80 2C 0F 14 50 0E 0E 9E 82 E7 69
    80    31 36 4B 54 46 31 47 36 34 48 5A 2D 31 47 36 45
    90    31 20 45 31 80 2C 44 50 41 45 50 45 54 30 30 33
    A0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    B0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    C0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    D0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    E0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    F0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Monitoring
Mainboard Model        8096 (0x000000D7 - 0x000022D0)
LPCIO
Hardware Monitors
Hardware monitor        Intel I/O
    Clock Speed 0        449.90 MHz [0x1C1] (Graphics)
    Clock Speed 1        n.a. (Memory)
    Clock Speed 2        n.a. (Processor)
Hardware monitor        NVIDIA NVAPI
    Clock Speed 0        405.00 MHz [0x195] (Graphics)
    Clock Speed 1        405.00 MHz [0x195] (Memory)
PCI Devices
Register space            PCI Express, base address = 0x0E0000000
Description            Host Bridge
Location            bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
    Vendor ID        0x8086
    Model ID        0x1604
    Revision ID        0x09
    PI            0x00
    SubClass        0x00
    BaseClass        0x06
    Cache Line        0x00
    Latency            0x00
    Header            0x00
PCI header
    Subvendor ID        0x103C
    Subsystem ID        0x8096
    Int. Line        0x00
    Int. Pin        0x00
PCI capability
    Caps class        Vendor Dependant
    Caps offset        0xE0
PCI registers
    00    86 80 04 16 06 00 90 20 09 00 00 06 00 00 00 00
    10    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    20    00 00 00 00 00 00 00 00 00 00 00 00 3C 10 96 80
    30    00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
    40    01 90 D1 FE 00 00 00 00 01 00 D1 FE 00 00 00 00
    50    C1 01 00 00 91 00 00 00 57 00 F0 9F 01 00 00 9D
    60    01 00 00 E0 00 00 00 00 01 80 D1 FE 00 00 00 00
    70    00 00 00 FF 01 00 00 00 00 0C 00 FF 7F 00 00 00
    80    31 11 11 11 11 33 33 00 1A 00 00 00 00 00 00 00
    90    01 00 00 FF 01 00 00 00 01 00 F0 5E 02 00 00 00
    A0    01 00 00 00 02 00 00 00 01 00 00 5F 02 00 00 00
    B0    01 00 00 9E 01 00 80 9D 01 00 00 9D 01 00 00 A0
    C0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    D0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF
    E0    09 00 0C 01 99 61 04 72 D4 00 5D 14 00 00 00 00
    F0    00 00 00 01 C8 0F 04 00 00 00 00 00 00 00 00 00 Description            VGA Controller
Location            bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
    Vendor ID        0x8086
    Model ID        0x1616
    Revision ID        0x09
    PI            0x00
    SubClass        0x00
    BaseClass        0x03
    Cache Line        0x00
    Latency            0x00
    Header            0x00
PCI header
    Address 0 (memory)    0xC3000000
    Address 2 (memory)    0xD0000000
    Address 4 (port)    0x00007000
    Subvendor ID        0x103C
    Subsystem ID        0x8096
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps class        Message Signalled Interrupts
    Caps offset        0x90
PCI capability
    Caps class        Power Management
    Caps offset        0xD0Happy Sacha Baron Cohen GIF by Amazon Prime Video
Number of adapters        2
Graphic APIs
API                D3D
API                NVIDIA I/O
API                NVIDIA NVAPI
API                Intel I/O
Display Adapters
Display adapter 0
    ID            0x4000000
    Name            Intel(R) HD Graphics 5500
    Board Manufacturer    Hewlett-Packard
    PCI device        bus 0 (0x0), device 2 (0x2), function 0 (0x0)
        Vendor ID    0x8086 (0x103C)
        Model ID    0x1616 (0x8096)
        Revision ID    0x9
    Performance Level    0
        Core clock    450.0 MHz
    Performance Level    Current
        Core clock    449.9 MHz
    Driver version        20.19.15.4549
    WDDM Model        2.0
Display adapter 1
    ID            0x1080108
    Name            NVIDIA GeForce 940M
    Codename        GM108
    Core family        0x118 (GM108-A)
    Cores            384
    ROP Units        8
    Technology        28 nm
    Memory type        DDR3 (Micron)
    Memory size        2 GB
    Memory bus width    64 bits
    PCI device        bus 10 (0xA), device 0 (0x0), function 0 (0x0)
        Vendor ID    0x10DE (0x0000)
        Model ID    0x1347 (0x0000)
        Revision ID    0xA2
    Root device        bus 0 (0x0), device 28 (0x1C), function 4 (0x4)
    Performance Level    Base
        Core clock    1071.5 MHz
        Memory clock    900.0 MHz
    Performance Level    Boost
        Core clock    1176.0 MHz
        Core clock    405.0 MHz
        Memory clock    405.0 MHz
    Driver version        27.21.14.6280
    WDDM Model        2.7
Win32_VideoController        AdapterRAM = 0x80000000 (2147483648)
Win32_VideoController        AdapterRAM = 0x40000000 (1073741824)
Win32_VideoController        DriverVersion = 27.21.14.6280
Win32_VideoController        DriverVersion = 20.19.15.4549
Win32_VideoController        DriverDate = 06/09/2021
Win32_VideoController        DriverDate = 11/10/2016
Monitor 0
    Model             ()
    ID            AUO38ED
    Serial
    Manufacturing Date    Week 43, Year 2014
    Size            15.3 inches
    Max Resolution        1920 x 1080 @ 60 Hz
    Horizontal Freq. Range    0-0 kHz
    Vertical Freq. Range    0-0 Hz
    Max Pixel Clock        0 MHz
    Gamma Factor        2.2
Software
Windows Version            Microsoft Windows 10 (10.0) Home Single Language 64-bit   (Build 19043)
DirectX Version            12.0
Register Spaces
Register space            PCI
Register space            PCI #2
Register space            SMBus, base address = 0x07040
