Main reason that I want to patch and learn to patch is because my charger doesn't seem to correspond with big sur macOS. Whether I plug the charger or not I get a ACPI error. Something about ADJP, ae-not-found and stuff. I could upload a kernel log but I don't know how to even begin or what app helps to do that. I searched some forums and the answer was to put in ACPI folder an SSDT which contains ADJP and PSS methods. To me it doesn't work but I let it in the folder anyway. So I want to learn how to patch.
1.How can I fix this ADJP-ACPI error?
2.If I want to patch any of the patches in Maciasl I get syntax error, 3 to be precise
here is a pic https://ibb.co/5v9Rp4d
Send me markoss-MacBook-Pro.zip
Edited by Μαρκος Γιασσα
Solved. All you got to do is to extract your DSDT and your SSDTS. Find the ssd that contain the ADJP and PSS method and put it in patched folder of your ACPI in your macOS's EFI folder. Then if you have another error, something about PSR just edit your DSDT and go to PSR method delete some texts and save it.
here is the example
Original For Clevo laptop.
Method (_PSR, 0, NotSerialized) // _PSR: Power Source
                      If (LEqual (^^WMI.HKDR, Zero)) //WMI: Some Windows thing?
                            If (LOr (\_TZ.TZ0.PPFG, LOr (^^PCI0.LPCB.EC.B15C, GPSF))) {}
                            ElseIf (And (PSF1, 0x30))
                                      ADJP (Zero) //What's this? ADJP not in the ACPI spec.
                      Return (ACFG)
Delete this
Last, it should be like this
                Return (ACFG)
Save your DSDT and your good to go.
Thanks this thread is solved
Enjoy!
