Need Help Acer V5-571 6869 DSDT
I have fixed most of common erros, but theses i have not found info about!
Thanks!
Here is the link of the two DSDT original and edited?
http://www.mediafire.com/?d9nwfak9kynv4yi
Line 7435 Store (GOST (), OSTP)
Method (_REG, 2, NotSerialized)
               If (LEqual (Arg0, 0x03))
                   Store (Arg1, ECON)
                   TINI ()
                   Store (0x05, SYSO)
                   If (LGreaterEqual (OSYS, 0x07D6))
                       Store (Zero, BNEN)
                   Store (BNEN, BCEN)
                   Store (BNVE, BCVE)
                   If (BCEN)
                       If (BCVE) {}
                   ^^^PEG0.PEGP.USPL (One)
               If (TSLD)
                   ^^^GFX0.GLID (MLID)
               Else
                   ^^^GFX0.GLID (One)
Line 7436 ^^^PEG0.PEGP.USPL (One)
                   Store (Arg1, ECON)
                   TINI ()
                   Store (0x05, SYSO)
                       Store (Zero, BNEN)
                   Store (BNEN, BCEN)
                   Store (BNVE, BCVE)
                   If (BCEN)
                       If (BCVE) {}
               If (TSLD)
                   ^^^GFX0.GLID (MLID)
               Else
                   ^^^GFX0.GLID (One)
Line 7961 If (LNotEqual (^^^GFX0.IGID, 0xFFFF))
    Scope (\)
       Mutex (MSGF, 0x00)
   Scope (_SB.PCI0.LPCB.EC0)
       Method (_Q5C, 0, NotSerialized)
           Store (0x5C, P80H)
       Method (_Q1C, 0, NotSerialized)
           Store (0x1C, P80H)
           If (BCEN)
               SDBN (BNVA, One)
           Else
               Acquire (MSGF, 0xFFFF)
                   BIAN (0x86)
               Release (MSGF)
       Method (_Q1D, 0, NotSerialized)
           Store (0x1D, P80H)
           If (BCEN)
               SDBN (BNVA, One)
           Else
                   BIAN (0x87)
               Release (MSGF)
       Method (_Q28, 0, NotSerialized)
           Store (0x28, P80H)
       Method (_Q29, 0, NotSerialized)
           Store (0x29, P80H)
           Store (Zero, \_PR.CPU0._PPC)
           PNOT ()
           If (ECON)
               Store (Zero, KCP1)
               Store (Zero, KCP2)
           Else
               MBEC (0x92, 0xDF, Zero)
               MBEC (0x92, 0x7F, Zero)
       Method (_Q2A, 0, NotSerialized)
           Store (0x2A, P80H)
           Store (Divide (SizeOf (\_PR.CPU0._PSS), 0x03, ), \_PR.CPU0._PPC)
           PNOT ()
           If (ECON)
               Store (One, KCP1)
               Store (Zero, KCP2)
           Else
               MBEC (0x92, 0xDF, 0x20)
       Method (_Q2B, 0, NotSerialized)
           Store (0x2B, P80H)
           Store (Divide (Multiply (SizeOf (\_PR.CPU0._PSS), 0x02), 0x03, ),
               \_PR.CPU0._PPC)
           PNOT ()
           If (ECON)
               Store (One, KCP1)
               Store (One, KCP2)
           Else
               MBEC (0x92, 0x7F, 0x20)
       Method (_Q2D, 0, NotSerialized)
           Store (0x2D, P80H)
       Method (_Q32, 0, NotSerialized)
           Store (0x32, P80H)
           HKEY (0x32)
           If (ECON)
               Store (Zero, KCTT)
           Else
               MBEC (0x92, 0xFD, Zero)
       Method (_Q33, 0, NotSerialized)
           Store (0x33, P80H)
           If (ECON)
               Store (Zero, KCSS)
           Else
               MBEC (0x92, 0xFE, Zero)
           NTMR ()
       Method (_Q34, 0, NotSerialized)
           Store (0x34, P80H)
           If (ECON)
               Store (One, KCSS)
           Else
               MBEC (0x92, 0xFE, One)
           NTMR ()
       Method (_Q35, 0, NotSerialized)
           Store (0x35, P80H)
           HKEY (0x35)
           If (ECON)
               Store (One, KCTT)
           Else
               MBEC (0x92, 0xFD, 0x02)
       Method (_Q36, 0, NotSerialized)
           Store (0x36, P80H)
           If (ECON)
               Store (One, KOSD)
           Else
               MBEC (0x92, 0xF7, 0x08)
           Sleep (0x01F4)
           NTMR ()
       Method (_Q3B, 0, NotSerialized)
           Store (0x3B, P80H)
           TRPS (0xCA, Zero)
       Method (_Q3C, 0, NotSerialized)
           Store (0x3C, P80H)
           TRPS (0xCA, One)
       Method (_Q3D, 0, NotSerialized)
           Store (0x3D, P80H)
           Store (0x03, \_PR.CPU0._PPC)
           PNOT ()
       Method (_Q40, 0, NotSerialized)
           Store (0x40, P80H)
           Notify (BAT0, 0x81)
       Method (_Q41, 0, NotSerialized)
           Store (0x41, P80H)
           Notify (BAT0, 0x81)
       Method (_Q48, 0, NotSerialized)
           Store (0x48, P80H)
           Notify (BAT0, 0x80)
       Method (_Q4C, 0, NotSerialized)
           Store (0x4C, P80H)
           If (B0ST)
               Notify (BAT0, 0x80)
       Method (_Q4D, 0, NotSerialized)
           Store (0x4D, P80H)
       Method (_Q50, 0, NotSerialized)
           Store (0x50, P80H)
           Notify (ADP1, 0x80)
       Method (_Q51, 0, NotSerialized)
           Store (0x51, P80H)
           Notify (ADP1, 0x80)
       Method (_Q52, 0, NotSerialized)
           Store (0x52, P80H)
           Notify (LID0, 0x80)
           If (TSLD)
               ^^^GFX0.GLID (One)
       Method (_Q53, 0, NotSerialized)
           Store (0x53, P80H)
           Notify (LID0, 0x80)
           If (TSLD)
               ^^^GFX0.GLID (Zero)
       Method (NTMR, 0, NotSerialized)
           Notify (\_TZ.TZS0, 0x80)
           Notify (\_TZ.TZS1, 0x80)
       Method (SBNL, 2, NotSerialized)
           If (BCEN)
               SDBN (Arg0, One)
       Method (SDBN, 2, NotSerialized)
I Will be posting the others codes!
Anyone? Please help, i have searched on net about there erros, but not found a clue, i believe this is advanced editing!
@Mirone, If you could help and post the solution here, i would apreciate! I'm really needing this to make OSX ML work! And since all versions of Aver V5-571 notebooks are the same bios, would help much more people! Thanks!
must of that errors are already in original dsdt... that bios is a mess..check in acer support if any bios update.
Yeah, i noticed that, i checked and all errors are present on bios 1.05 and 1.14, there is a new UEFI bios 2.09, but apparently that is the one Locked for Windows 8 only!
If i can't fix i believe that i'm doomed, because seems that from now on they only will launch bios for windows 8. Since the microsoft is moving to strings to the Signed code from bios serial!
Hello,
fix the syntax errors and the other ones will be gone.
    Scope (_SB.PCI0.PEG0.PEGP)
       OperationRegion (DGPU, PCI_Config, Zero, 0x10)
       Field (DGPU, AnyAcc, NoLock, Preserve)
           DGID,   16,
           GDID,   16
       Method (_DOS, 1, NotSerialized)
           Store (And (Arg0, 0x03), DSEN)
           Store ("----- DGPU _DSM --------", Debug)
           If (LEqual (GPUT, 0x03))
               If (LOr (LEqual (PMDP, 0x04), LEqual (PMDP, 0x03)))
                   If (LEqual (Arg0, Buffer (0x10)
                               /* 0000 */   0xF8, 0xD8, 0x86, 0xA4, 0xDA, 0x0B, 0x1B, 0x47,
                               /* 0008 */   0xA7, 0x2B, 0x60, 0x42, 0xA6, 0xB5, 0xBE, 0xE0
                       Return (NVOP)
                   Store ("<<< _DSM - Perf >>>", Debug)
                   Store (Arg0, Debug)
                   Store (Arg1, Debug)
                   Store (Arg2, Debug)
                   Store (Arg3, Debug)
                   If (CMPB (Arg0, Buffer (0x10)
                               /* 0000 */   0x01, 0x2D, 0x13, 0xA3, 0xDA, 0x8C, 0xBA, 0x49,
                               /* 0008 */   0xA5, 0x2E, 0xBC, 0x9D, 0x46, 0xDF, 0x6B, 0x81
                       Return (NVGS)
Very much Thank You!
:D
Now is all fine! I have anexed the file to the post, for anyone what may have a Acer V5-571 notebook!
This post may help other to fix errors from V5-571P and 571G models too!
Hello,
           DGID,   16,
           GDID,   16
                       Return (NVOP)
                   Store (Arg0, Debug)
                   Store (Arg1, Debug)
                   Store (Arg2, Debug)
                   Store (Arg3, Debug)
                       Return (NVGS)
V5-571.aml.zip
I have two questions.
During the process of downgrading bios from 1.14 to 1.05 i have lost the UUID and Serial Number from bios, there is a way to recover it?
And now after put the DSDT.aml on extra folder the notebook, don't recognizes the USB ports and PS2 ports anymore.
Why use a patched DSDT if you make no relevant changes to it?
Only fixing compilation warnings and errors won't help. Actually in some cases, "fixing" warnings (like replacing CreateDWordField by CreateQWordField or editing Range Minimum/Maximum/Length values) can cause more harm than good.
I apreciate your help, but mine was with zero too.
I have tried, but same errors. I have found that thjs problem is that was taking to long to recognize the periphericals after boot, giving the impression of not functioning.
Later Edited: I Have fixed those problems adding, Kernel Cache and mach_kernel! Now that have DSDT i added those and booted fine! Before of dsdt these options would crash the boot.
try This:[attachment=0]dsdt.aml.zip[/attachment]
0errors, 0warnings, 0remarks
I will dio this next, i am learning yet. What modifications you think is good to do?
I have these problems:
ALC 269, Not recognized.
No cpu power management, would be good for battery economy!
Video HD4000 only recognized addind the Device-Propriets on boot loader chameleon. But that is good since is working...
What modifications would be recommended to fix these fix two problems?
Try this:[attachment=0]dsdt.aml.zip[/attachment]
Thanks! You are quick! What modifications did you do? Just to be sure, what tests should i make.
But now i installed Vodoo HDA 2.7.4 r6 and sound is working! Thanks!
You have to convert (gfxutil) both hex strings to plist, merge them, then convert back to hex. If you merge hex strings the result will have duplicated header.
Example:
<plist version="1.0">
<dict>
   <key>PciRoot(0x0)/Pci(0x1c,0x5)/Pci(0x0,0x0)</key>
   <dict>
       <key>built-in</key>
       <string>0x01</string>
   </dict>
   <dict>
       <string>0x01660003</string>
   </dict>
</dict>
</plist>
You can also inject ethernet built-in via DSDT.
http://Olarila.com/forum/viewtopic.php?f=7&t=383
About power management
http://Olarila.com/forum/viewtopic.php?f=18&t=1703
