Asus Rampage Formula - Sound Driver
Hello,
I have installed iAtkos L2 on my computer, everything work well except the sound. I have an Asus Rampage Formula (chipset X48).
Do you have any idea about the process to follow to enable it ?
Thanks in advance for your replies.
terminal
sudo kextcache -prelinked-kernel
or
terminal
or
Hello,
I have this message in the terminal when I do this:
Can't read info dictionary for VoodooHDA.kext: IOCFUnserialize: syntax error near line 35.
/System/Library/Extensions/System.kext/PlugIns/Libkern6.0.kext doesn't support architecture x86_64; omitting from prelinked kernel.
My Info.plist is attached.
Info.plist.zip
something wrong with the kext voodoohda
the other msg is normal no problem
try another voodoohda
Hello,
I have tried several voodoo and nothing worked.
