AMD Radeon R9 270X Triple Monitor Problem
Hello Maldon,
I want to use 2 monitor and 1 TV at the same time. My GPU has 2DVI + 1HDMI and 1 Display Port
2 Monitors connected by DVI to HDMI cable and TV connected by HDMI to HDMI. Only 1 monitor and 1 TV starts or 2 monitors work at the same time but no success 3 ports!
Can you check run me post and advice?
Thanks.
Send me Sanelek-iMac.zip
In generosity and helping others, be like a river
In compassion and grace, be like the sun
In concealing others’ faults, be like the night
In anger and fury, be like a dead
In humility and modesty, be like the earth
In tolerance, be like the sea
Either look as you are or be as you look
by Rumi
check csm option on bios/uefi
*edit
bro
change smbios to iMacPro1,1
*edit
bro
CSM must be disabled, right?
Smbios was Mac Pro 6.1 and everything works perfect except third monitor. I will try with imacpro 1.1
by Rumi
hardware accel and other things dont work with this smbios
sorry this configuration is little away to me to test and had just found a chance to try SMBIOS iMacPro1,1 and Mac Pro7,1 without success to display third monitor.
Some pictures.
https://ufile.io/viwx5cpc
https://ufile.io/f/vokm9
Some pictures BIOS settings.
https://ufile.io/f/acj8r
Edited by uisik34
by Rumi
i think in this case only if u change connector
for amd is very hard
Can Hackintool do a trick? How can change connector, do you mean display port to HDMI to test?
by Rumi
