MSi Z370 - MAG TOMAHAWK - Olarila Monterey installation IMPOSSIBLE
H guyes ,
i joing OLARILA forum since 8 days , starting to learn how to make install , reading almost guide, installed KEXT, ACPI , and all thing needed regarding my PC , but installation fail since 8 days
Hardware:
Motherboard:
MSi - Z370 MAG TOMAHAWK .
CPU:
Intel Core i3-9100F 3,60 GHz - Coffee Lake.  Intel 300-series chipset
No iGPU.
Graphic Video:
Internal Microsoft Base Video Display.
PCI\VEN_10DE&DEV_1C81&SUBSYS_33541462&REV_A1
BIOS Config:
All is OK .
- Unplugged NVIDIA GRAPHIC Card , the card is disabled.( Nvidia GTX 1050 )
Ethernet:
Intel(R) l211 Gigabit Network Connection.
IMAGE USED:
- Olarila Monterey Beta 6.raw
- Monterey Beta 6 with EFI folder for chipset series 300, 400 and 500
Software used:
Win32Disk Imager
EFI used:
- Olarilla EFI when flashing .raw usung Win32DiskImager.
install begin PERFECT , arrive to 18min during install all FREEZ.
- Olarila EFI - OC series 300.
install begin and FAIL at 16min.
Thie is a snapshot done during installation , error are posted , to let everyone understand , from where is the problem.
Thank's for every one here , who can help me installing OLARILA Monterey Beta 6.
Quentin.
EFI-OLARILA MSI-Z370-Coffee Lake.rar
Edited by Quentin-83
Update: EFI
what gpu?
Just now, MaLd0n said:
what gpu?
Hi Maldon ,
i disabled my nVidia  GPU.because I read that it must be deactivated before installation.
My GPU is : nVidia GTX 1050.I'm using now Microsoft Base Video internal display ( MicrosoftDisplay.sys).
27 minutes ago, MaLd0n said:
u need put one amd card with this folder
https://tinyurl.com/rrkkyduy
Ok Maldon. I will change EFI and use this one , and show you the result in a moment.
Folder changed with : EFI.Opencore.Desktop.CoffeeLake
Result
PANIC 1:
PANIC 2:
EFI Used:
Update:Snapshot
put one rx560+
1 minute ago, MaLd0n said:
put one rx560+
Hi Maldon ,
i don't have AMD GPU , i only have Nvidia GPU GTX 1050
Best Regard's
Quentin
boot argument:
nv_disable=1 -v alcid=1 watchdog=0 agdpmod=pikera dk.e1000=0 -no_compat_check
