Hi,
I hope you guys dont rip me in half. I would like to build my first DTDT but I am not sure what Patches I need.
I extracted my DSDT with the editor and applied the soundcard patch ALC889 and compiled it. After that I hit the button "fix errors".
It did fix 333 errors but I guess thats not enough.
Do I need to add patches like DTGP.txt or EHCI.txt or RTC.txt and so on (i.e. ethernet)? How do I know what patches I need?
I know that my mobo is not in the list (MSI H55M-E33) but I would like to get my hands on this.
My rig specs are:
i3-550 (HD3000)
8GB Ram 1333
ATI 5770
Sound ALC889
Ethernet RTL8111
Thx for any direction.
Thx for the fast reply.
I did read the linked article but how do I know what kind of patch I need? Is it just try and error?
I mean the patches in the editor folder are poorly described/dokumented for whats they are for.
Or can I see maybe in logfiles where something fails and I can apply a patch and so on?
It's not try and error, but read and observation.
If everything works well without patches, you don't need any.
If something is not working right, you probably need patches listed under respective fields (power management, sleep, USB, etc).
