Need help with creating a DSDT for a Gigabyte GA-Z77-UD5H
Hello all,
i am reading in the OSX86 scene for quite a while now and am trying to build a hackintosh myself for some time now. I started with a Asus P8Z68-V Pro mainboard but had several problems and it wasn't stable. So i decided to exchange it and get a Gigabyte mainboard because the support in building a hackintosh on them is way better.
I never really got a good working setup for sleep with the Asus no matter what was connected, set in Bios (patched to 3402) or trying different DSDT's (even creating one myself).
So my new Set for the hackintosh is now:
Intel Core i7 2600k
Gigabyte GA-Z77X-UD5H (UEFI F14)
8GB RAM
Geforce 560 Ti
OCZ Vertex 240 GB
Sonnet Network Card Presto Gigabit Pro
I started with putting the hackintosh together with the Gigabyte, made a fresh install of Mountain Lion with a unishit USB Stick and updated to 10.8.2.
Installed multishit Options:
UserDSDT or DSDT-Free Installation
ALC898 without DSDT (as i had no DSDT at that time - might change it later when DSDT is working)
Trim Enabler 10.8.1+
Fake SMC Plugins
This made a smbios.plist with MacPro3,1 and a org.chameleon.Boot.plist :
GenerateCStates
Yes
GeneratePStates
Yes
Graphics Mode
1920x1200x32
GraphicsEnabler
Yes
Kernel
mach_kernel
Kernel Flags
darkwake=0
Legacy Logo
Yes
RestartFix
No
Timeout
2
UseKernelCache
Yes
Now booting without the Stick and HOOORRRAAAYYYYY it works with sleep and wakup with a mouse click!!!!! Oh GREAT! :D
Then i connected the rest of my peripherals to the USB Ports and F**** :evil: sleep is not working anymore…
By disconnected one after another i found out that two USB devices a causing the problems:
- my monitor has a USB-Hub with a cardreader and a cam built in
- a cardreader with USB Ports on the main case of the hackintosh
Arg… i thought i could get around the DSDT and have a Hackintosh without a DSDT…
When i try to put the hack to sleep it wakes up immediately and has this in the log:
17.11.12 11:37:29,000 kernel[0]: Wake reason: GLAN EHC2 EHC1
17.11.12 11:37:29,000 kernel[0]: The USB device HubDevice (Port 1 of Hub at 0x1a000000) may have caused a wake by issuing a remote wakeup (2)
17.11.12 11:37:29,000 kernel[0]: The USB device HubDevice (Port 1 of Hub at 0x1d000000) may have caused a wake by issuing a remote wakeup (2)
17.11.12 11:37:29,000 kernel[0]: The USB device 4-Port USB 3.0 Hub (Port 3 of Hub at 0x14800000) may have caused a wake by issuing a remote wakeup (1)
17.11.12 11:37:29,000 kernel[0]: The USB device 4-Port USB 3.0 Hub (Port 4 of Hub at 0x14800000) may have caused a wake by issuing a remote wakeup (1)
17.11.12 11:37:29,000 kernel[0]: The USB device HubDevice (Port 1 of Hub at 0x1a100000) may have caused a wake by issuing a remote wakeup (3)
17.11.12 11:37:29,000 kernel[0]: The USB device Microsoft® 2.4GHz Transceiver V1.0 (Port 2 of Hub at 0x1a100000) may have caused a wake by issuing a remote wakeup (3)
17.11.12 11:37:29,000 kernel[0]: The USB device HubDevice (Port 4 of Hub at 0x1a110000) may have caused a wake by issuing a remote wakeup (3)
17.11.12 11:37:29,000 kernel[0]: The USB device Digital Picture Frame (Port 2 of Hub at 0x1a114000) may have caused a wake by being disconnected
When i disconnect the two "problem" devices i get the following messages in the log with the woking sleep:
17.11.12 11:43:53,000 kernel[0]: Wake reason: GLAN EHC2
17.11.12 11:43:53,000 kernel[0]: The USB device HubDevice (Port 1 of Hub at 0x1a000000) may have caused a wake by issuing a remote wakeup (2)
17.11.12 11:43:53,000 kernel[0]: The USB device 4-Port USB 3.0 Hub (Port 4 of Hub at 0x14800000) may have caused a wake by issuing a remote wakeup (1)
17.11.12 11:43:53,000 kernel[0]: The USB device 4-Port USB 3.0 Hub (Port 3 of Hub at 0x14800000) may have caused a wake by issuing a remote wakeup (1)
17.11.12 11:43:53,000 kernel[0]: The USB device Microsoft® 2.4GHz Transceiver V1.0 (Port 2 of Hub at 0x1a100000) may have caused a wake by issuing a remote wakeup (3)
Made me think the problem has to be with the EHC1...
So i started with extracting the DSDT and got errors, remarks and warnings:
Non-hex letters must be upper case (pnp0c14) -> got fixed be hitting "Fix errors"
Rescource Tag larger than Field -> CreateDWordField changed to CreateQWordField -> clear
Result is not used, possible operator timeout will be missed -> Patch with Possible operator timeout is ignored.txt -> clear
_HID suffix must be all hex digits (GH) -> solved by changing "Name (_HID, "ABCDEFGH")" in "Name (_HID, "ABCDEF12")"
Reserved method must return a value (Integer/String required for _HID) and Not all control paths return a value (_HID) (Both Warnings for the same line)->
	Method (_HID, 0, NotSerialized)
           If (TCMF) {}
           Else
               Return (0x0201D824)
changed to :
           If (TCMF)
               Return (Zero)
           Else
               Return (0x0201D824)
Several Remarks (Use of compiler reserved name (_T_0) & (_T_1) -> solved with the _T_x rename.txt Patch
Done all that, i have a DSDT throwing no errors, warnings or remarks to start to try to get sleep working.
I read on the forums that removing _PRW Methods would solve the problem. I went to the device EHC1 and removed the part:
            Method (_PRW, 0, NotSerialized)
               Return (GPRW (0x0D, 0x04))
But that didn't help… same messages in the log as before the remove of the EHC1 _PRW Method.
Than i found a thread about changing the _PSW Method from:
            Method (_PSW, 1, NotSerialized)
               If (Arg0)
                   Store (Ones, PWUC)
               Else
                   Store (Zero, PWUC)
to:
               If (Arg0)
                   Store (Zero, PWUC)
               Else
                   Store (Zero, PWUC)
But that didn't help either… same messages in the log as before the remove of the EHC1 _PRW and _PSW Method.
Then tried with darkwake=10 and without darkwake, but it didn't help... tried this ... and that ...
I am a little lost now… use the hackintosh without the cam and the cardreaders is not really an option…
I'd really appreciate it, if someone could help me and maybe others having problems with sleep and USB devices. Maybe i just don't see the right spot?
I'll attach the DSDT for the GA-Z77X-UD5H with the errors cleared, but no other changes or patches.
Are there other patches i should use on the DSDT for my mainboard? Or should other parts be changed?
Many many many thanks for your help
Racerx
Thanks for your help artur-pt, but still have the problems with the two devices connected. The hack goes to sleep and immediatly wakes up but i noticed the screen stays black until i click with the mouse.
Messages from the Log:
17.11.12 22:08:33,000 kernel[0]: Wake reason: GLAN EHC2 EHC1
17.11.12 22:08:33,000 kernel[0]: The USB device HubDevice (Port 1 of Hub at 0x1d000000) may have caused a wake by issuing a remote wakeup (2)
17.11.12 22:08:33,000 kernel[0]: The USB device HubDevice (Port 1 of Hub at 0x1a000000) may have caused a wake by issuing a remote wakeup (2)
17.11.12 22:08:33,000 kernel[0]: The USB device 4-Port USB 3.0 Hub (Port 3 of Hub at 0x14800000) may have caused a wake by issuing a remote wakeup (1)
17.11.12 22:08:33,000 kernel[0]: The USB device 4-Port USB 3.0 Hub (Port 4 of Hub at 0x14800000) may have caused a wake by issuing a remote wakeup (1)
17.11.12 22:08:33,000 kernel[0]: The USB device HubDevice (Port 1 of Hub at 0x1a100000) may have caused a wake by issuing a remote wakeup (3)
17.11.12 22:08:33,000 kernel[0]: The USB device HubDevice (Port 4 of Hub at 0x1a110000) may have caused a wake by issuing a remote wakeup (3)
17.11.12 22:08:33,000 kernel[0]: The USB device Digital Picture Frame (Port 2 of Hub at 0x1a114000) may have caused a wake by being disconnected
Try removing method _PRW from devices in "wake reason" (GLAN, EHC2, EHC1).
dsdt.aml.zip
Thanks Cassio for you helping, but that didn't fix the problem either. The log still says:
17.11.12 22:47:46,000 kernel[0]: Wake reason: EHC2 EHC1
17.11.12 22:47:46,000 kernel[0]: The USB device HubDevice (Port 1 of Hub at 0x1a000000) may have caused a wake by issuing a remote wakeup (2)
17.11.12 22:47:46,000 kernel[0]: The USB device HubDevice (Port 1 of Hub at 0x1d000000) may have caused a wake by issuing a remote wakeup (2)
17.11.12 22:47:46,000 kernel[0]: The USB device 4-Port USB 3.0 Hub (Port 3 of Hub at 0x14800000) may have caused a wake by issuing a remote wakeup (1)
17.11.12 22:47:46,000 kernel[0]: The USB device 4-Port USB 3.0 Hub (Port 4 of Hub at 0x14800000) may have caused a wake by issuing a remote wakeup (1)
17.11.12 22:47:46,000 kernel[0]: The USB device HubDevice (Port 1 of Hub at 0x1a100000) may have caused a wake by issuing a remote wakeup (3)
17.11.12 22:47:46,000 kernel[0]: The USB device HubDevice (Port 4 of Hub at 0x1a110000) may have caused a wake by issuing a remote wakeup (3)
17.11.12 22:47:46,000 kernel[0]: The USB device Digital Picture Frame (Port 2 of Hub at 0x1a114000) may have caused a wake by being disconnected
Have you tried changing _PSW in both devices like below?
               Store (Zero, PWUC)
Did you try to disconnect the device "Digital Picture Frame"?
Can I always use DSDT.aml, open and change things - Or do i have to use the .dsl i saved? the .aml is compiled, right? But i still see the text...where is the difference?
As i wrote, when i disconnect the two USB devices ( my HP monitor's USB (cam, cardreader and USB-Hub) and the cardreader in my case) sleep is working...
I think i did change the _PSW in the EHC1. But not in EHC2, but...
I don't think the EHC2 brings any problems, because with the working sleep when the two devices a disconnected, the EHC2 shows in wake reason, but sleep was been working correct then..
Anyway i'll try it right now...stay tuned :)
Changing the _PSW made it worse...
I took the DSDT.aml from Cassio opened it and changed it like you wrote...
my hack goes to sleep, immediately wakes again but froze then right away...only to recover with a reset.
Hmmmm....
Olá amigo o problema é que dependendo da versão da bios o dsdt e diferente as vezes o computador tem comportamentos diferente tenta essa. A minha versão da bios: z77xud5h.16h
Identificador do modelo: iMacPro1,1
Placa Mãe: Asus TUF Z390-PLUS GAMING (WI-FI)
conjunto de chips: Intel Z390
Memoria RAM: 1x16 GB Corsair 3000 MHz DDR4
Processador: Intel Core i7-8700K 3.70GHz
Placa de Video: Sapphire Radeon RX 590 NITRO+ Special Edition Dual, 8GB
Wireless/Bluetooth: BCM943602CS 16000Mbps 802.11AC
