X79 Shutdown Problem/ Notebook Sleep/Battery indicator
Hey MaLd0n,
I have a x79 dual CPU board with one Xeon E5 2680 (C602 Chip). the system won't shut down completely :-( but reboot work. And macOS Monterey stuck at waiting for root device. with big sur everything is running very well.. I think there could be a problem with the pci lane.. it would be Wonderful, if you could take a look :-)
and if it is allowed to post two DSDTs, I have a Medion Akoya S6212 Notebook where the battery status bar and sleep won't work :-( (Sleep already worked without the injected DSDT)
https://wetransfer.com/downloads/64d549df3801c241746a93d45d633a3520210908174952/28b0836956e5baadfc397cc7ba332ab320210908175008/737c39?utm_campaign=WT_email_tracking&utm_content=general&utm_medium=download_button&utm_source=notify_recipient_email
Thank you very much !!!
Edited by taube111111
try fadtenablereset
ur folders have man y acpi renames, not good
seems like a usb 3 card problem
remove and confirm
hey ,
I removed the USB 3 Card and disabled XHCI unsupporded kext
i also disabled usb 3 in bios after this
the system still wont shut down
