If you downloaded one of the USB images in my signature and got "operating system not found" error after copying the raw image and booting from USB, use some partition manager to make the partition active and try again. Looks like some BIOSes have problem if the partition is not marked as active.
You can also extract the 3 files in the attachment to the same folder as the raw image and run patch.bat as administrator. You should see
rawwrite dd for windows version 0.6beta3.
Written by John Newbigin <jn@it.swin.edu.au>
This program is covered by terms of the GPL Version 2.
notrunc
1+0 records in
1+0 records out
Pressione qualquer tecla para continuar. . .
Then copy the raw image to the USB drive and try again.
patch.rar
