Hi, i need help....
i installed ML 10.8.2. now i've to fix a couple of things (audio ad1988b sleep and shutdown (shutdown some time works sometime half shutdown - monitor off but fan and case on))
on lion 10.7.4 i used a perfect working dsdt and everything worked perfectly (thanks to oldpam).
Now i in my extra folder i put the same dsdt.aml the boot hangs on : IOAPIC:Vesrion 0x20 Vector 64:87.
I know that t make everything works i need a waorking dsdt.
Any suggestion???? (p5e3 deluxe, q6600, gtx 550 ti, 8 gb ddr3 corsair)
(ps: without dsdt.aml i can boot ML, but audio, sleep and shutdown doesn't work)
Lion 10.8.4, q6600 - p5e3 deluxe GTX 550 ti 1 gb - 8 gb ddr3 corsair 1600
if u hardware is the same , nothing to do with dsdt
the dsdt is always the same for that hardware
probably u are not using the right kext for that hardware in 10.8
some people think dsdt is GOD or the salvation, is not without the right kext
The stange thing is that without dsdt i can boot, with dsdt it hangs.....
try to use this kext from lion in 10.8
AppleAPIC.kext
I'll try ASAP, in the main time i tried tu use dsdt patched from ASUS p5E.... now audio and shutdown works, but if try sleep, pc is off, but wen i try pu awake pc goes on monitor off.... i i force shutdown rct reset...... u used also applerct.kect from 10.7.3........ the same......
AppleAPIC.kext
i tried but is the same, anyway i extracted dsdt with dsdt editor, i applied ASUS P5E.txt patch from folder patch in dsdt editor......
now..... audio is ok, and shutdown too.
if i try to sleep.... my pc goes spleen, but when i wake (S3 only) it wakes, but desk freeze and is locked.... now i'll try AppleACPIPlatform.kext from Lion 10.7 and i cross my finger :roll:
No solution found . when i wake from sleep i've only "half Wake" (Pc on Monitor off).
any Suggestion??
Using AppleACPIPlatform from 10.7.3 fixes the problem here
http://www.insanelymac.com/forum/topic/199816-asus-p5e-dsdt-fixes/page__st__260#entry1836667
Make sure you have in BIOS
Advanced - CPU Configuration - Execute Disable Bit - Enabled
Your tips are always.... precise!!!!! thanks a lot. (the strange thing is that i tested it before and it frozen my desktop...... now i undestand why!!! If i wake from power button is perfect.... but if i wake it from mouse or keyboard (the test i made before changing a lot o things) after desk comes up after a couple of second if freeze. anyway is a no problem)
really thanks.
problem solved :D
For everyone still have problem with 10.8.2 and gtX 550 ti (OR OTHER CARDS SUPPORTED BY DRIVER):
important.... reboot only at the end!!!!
1) download and install Nvidia CUDA 5.0 for Mac
2) download and install 10.8.2 nvidia driver http://www.nvidia.com/object/macosx-304.00.05f02-driver.html (don't worry if in the end u get an error)
3) in Terminal type :
sudo perl -pi -e '$c+=s/\x8b\x81\x1c\x0c\x00\x00\xeb\x06\x8b\x81\x20\x0c\x00\x00/\xb8\x02\x00\x00\x00\x90\xeb\x06\xb8\x00\x00\x00\x00\x90/; END { printf "%s: %d substitution%s made.\n",($c==1 ? "Success" : "Error"),$c,(!$c || $c>1 ? "s" : ""); $?=($c!=1); }' /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
AFTER THAT you should get something like Substitution = 1 if it worked!!!
4) with kextwizard install (in S/L/E) LegacyAGPM.kext and AppleACPIPlatform.kext and repair permissiono (EXTRA AND S/L/E)
5)OPEN DISKUTILITY AND REPAIR PERMISSION.
6) REBOOT AND ENJOY.
