Freezes with Olarilla Big Sur on SP4 after 5 minutes.
Hi everyone!.
Two days ago, i finally archieved the installation of Olarilla Big Sur on my SP4 (i5, 8GB of RAM, 256 SSD).
It was too difficult because i needed to get the correct version of the drivers so that my SP4 could exit from the "+++++" state while macOS was starting up. For that reason, i ended up to using bigsadan's OpenCore and i finally got it.
However, i noticed that after 5 minutes, the cooler of the computer started to run and the screen started to freeze five by five seconds all the time. It makes the computer unusable. Afterwards, i tried to shutdown the computer, but it got stuck. (I've uploaded the screenshots that explain that here: https://imgur.com/a/HquJtxQ).
All in all, if i try to shutdown the computer before the cooler starts to run, it can shutdown perfectly.
To sum it up, i've been inquiring some posts and i haven't found an answer to sort out this upsetting issue .I'm actually wondering if there are missing some drivers or kexts on OC folder. I haven't modified the OC folder of bigsadan.
Thank you so much beforehand!!!
Edited by Winground
check cpu friend
not good and old bootloader version
check if boot is fine with this efi
https://tinyurl.com/uwmz3nzh
if work extract one sendme with this efi folder
Hi!.
Thank you so much for your answer.
The OC that you gave me doesn't work. It returns me the next lines:
OC: Driver CrScreenshotDxe.efi at 0 cannot be loaded - Access Denied!
Halting on critical error.
Thank you so much beforehand.
check ur procedure
dont use merge
dont use drag and drop
Hi.
I've been testing more ways to copy EFI Folder in EFI Partition but it's still returning me
I didn't use merge and drag & drop.
What can i do?
Thank you so much!.
u used a bootkey and select usb stick with this folder or ssd with this folder
I’ve put this EFI folder into the EFI partition of my SSD, which macOS uses as disk.
Also, I’ve tried it with USB stick and it didn’t work either.
