Screen
Hi, the touchpad is not working even though it has been patched. Elan touchpad. I'm leaving my screenshot and efi folder here, can you take a look, please?
Edited by AndrevMask
26 minutes ago, MaLd0n said:
IOREG dump failed. Retrying by increasing delays...
Increased delay by x3 times. Retrying...
IOREG dump has failed 3 times. Dumping generic IOREG report instead.
No matching processes belonging to you were found
Why am I getting an ioreg error in the runme application? catalina.
Is there no other way to send my system files to you?
just wait app finish
Okay, I waited and I guess I should pass this report on to you. But I can't send it to you, it says the size is big. I'm using someone else's efi folder. Can you create a custom efi for my device dude? And where else can I send this report to you other than here?
upload in some service like google drive or other
remove all acpi renames, reboot and extract new sendme
https://drive.google.com/file/d/1mwD58i0DYdIveHprURMi09UCsxCPR-Ak/view?usp=sharing
Hello, mald0n. When we cleared the patches, hackintosh didn't open. Instead, I'm sending you the output of my ssdt file through windows.
start with Olarila folder for ur hardware
is a clean config for one good start
Hello Mald0n. I have done the installation. I leave the runmee report here.
https://drive.google.com/file/d/1xy3--XQR0iokEeUbG4wPMF0Bz9PTyhbE/view?usp=sharing
the problem:
