Hi everyone , i've successfully hackintoshed my acer tablet . Everything works like a charm and macOS runs even better than Windows but i have a little issue : When i try to use imessage or FaceTime it closes as soon as when i log in . It doesn't show any message the app closes then reopen at the login screen . I've followed the guide for iservices but nothing . Everything seems to be ok , my serial number isn't valid at check coverage . Please @MaLd0n  i need some help . i'm using OC 0.7.2 . More info in the attachements , thanks .
ATTACHMENTS.zip
Edited by Lucari0_007
u need a good and valid serial
Try the method i posted about imessage it may help you. Generate yoiur serial copy it to system serial number and then copy paste it to your board serial and then add 5 random letters numbers to the end ofyour board serial making it = 17 letters numbers all together. then generate a new system uuid with terminal or occ whichever. Once generated copy it to your system uuid and thn take the last 12 digits in that system uuid and copy it to your ROM. Now reboot and try and login. I assume that you know ethernet is to say en0 and built in
On 3/4/2022 at 5:42 PM, Hacumak werd alvares said:
hi i have this problem in monterey ok , now I have a MacBook that don't use any more (ihave other board)
this MacBook is from 2010 the white macboks can use the serial on this hackintosh?
  1. Your serial is connected to your SM Bios. So incase your using a macbook 2010 SMBIOS on current machine running Monterey which I doubt that You are, then the answer would be "No" I mean you can try it but I dont think it will work.
  2. HOWEVER THE METHOD BELOW HAS WORKED FOR ME HUNDREDS OF TIMES "Yes I clean Install quite alot"  for friends and my machines etc. Lol
   Four things need your attention okay.
  1.   System Serial Number=CO7X19JMGJYVX
  2.  Board Serial Number=C07HGWGNJVRGGKHDF.                                              <--examples
  3. System UUID=C69HTFSD-4898-M8ED-7ZVC-JQDFERTDSECL
  4. ROM= E4 E5 D4 D5 C4 C5
            Once you have generated your own personal serials, use the method described here in contrast to the above,You want  yours to look like this. It is very simple just utilize the serial number & the last 12 digits of UUID whatever they are. So if you generated the numbers above for example then here is what you want it to look like below for example.
  1. SystemSerialNumber=C07X19JMGJYVX
  2. BoardSerialNumber  =C07X19JMGJYVXGKHDF
  3. SystemUUID = C69HTFSD-4898-M8ED-7ZVC-JQDFERTDSECL
  4. ROM =JQDFERTDSECL
Now continue thourgh installation and you should be okay. It has worked for me 100s of times doing clean install with same apple id. If you dont want to clean install then ae quite a few steps that you will have to do involving deleting and cleaning up networks folder and caches imessage folder caches etc. Otherwise it will fail if you dont. I wold leave a link but imnot sure if The sites administrator Maldon is cool with referencing other sites that are of the Hackintosh Subject because they can or could be found by searching the Olarila archives? So a quick Google search will land you where u need to go . Hope this helps.
Edited by rickiethadragon
