So i Created 0.7.2 EFI With SSDTTime SSDT's ‘cause i'v been using prebuilt SSDT's till now but seems like SSDTTime SSDT's Not Workin' Had some brightness slider issue so i used the Prebuilt SSDT's
The Big Problem For Me now is Shutdown is not workin' and MacOS Boot Time is more than 10 Seconds before it was 3 to 4 Seconds, I'll Attach The USB Ports Screenshot and EFI & DSDT Link.
I'm Currently on macOS 11.5.1 I'd be so grateful if you guys can tell me what's the issue and how to solve it.
My EFI & DSDT : Tap Here For Link
My Laptop Specifications :
Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
Motherboard : Mobile Intel HM170
Memory : 8 GB Samsung
Display : 1920 x 1080 (Full HD) IPS
GPU : NVIDIA GeForce GTX 960M 4GB(not workin')
Wireless NIC : Intel Dual Band Wireless-AC 3165
Audio : Realtek ALC235
‘bout the GPU "i cleaned my laptop and somehow from motherboard GPU is not workin' and not showin' in windows & also i turned it off from BIOS"
USBMap : This are the only ports active 1 usb 2, 2 usb 3.0, one bluetooth and camera ??‍♂️
 #                Discover USB Ports                   #
    ----- XHC@14 Controller -----
 1. HS01 | AppleUSB20XHCIPort |  1 (01000000) | 14100000 | Type 0
    - Cruzer Blade
 2. HS02 | AppleUSB20XHCIPort |  2 (02000000) | 14200000 | Type 3
    - Lenovo 510 Wireless Combo Keyboard & Mouse
 3. HS03 | AppleUSB20XHCIPort |  3 (03000000) | 14300000 | Type 3
    - Cruzer Force
 4. HS04 | AppleUSB20XHCIPort | 11 (0b000000) | 14400000 | Type 255
    - BroadcomBluetoothHostControllerUSBTransport
 5. SS01 | AppleUSB30XHCIPort | 22 (16000000) | 14500000 | Type 255
    - Intel(R) RealSense(TM) 3D Camera (Front F200)
Just now, Sam Gon said:
No did not work
what happens
post one photo
ok. but u need extract one sendme with my folder above
is folder boot is fine, extract one sendme
Boot is fine sir sorry I took so long I was out of town, and I lost the efi you gave me so this one is from my efi Send me samgons-MacBook-Pro.zip
boot from ssd not from usb
is not my folder
is a strange problem
some mistery
all looks good
u can remove all usb devices for check if problem is some device connected
