Hello
Can you help me please?
I have an acer XC885 pc with an integrated UHD630 graphics card I install Big Sur and the verbose works without problem
then after I see my Big Sur office for 2 Segondes !!!
then I lose the signal and my screen goes black :(
if I remove the HDMI cable from behind the pc and put it back as soon as possible
the image of Big Sur and back !!!
every time i turn on the pc i have to remove the hdmi plug
then put it back and the image comes back ....
Can you help me please ??
I'm on OpenCore
hello MAldON
can you help me to do it please?
I'm new to hackintosh and I don't understand everything
please help me to do it with me
Thank you
check hackintool.app
have many patches there
create a video patch and use igfxonln=1 bootarg
reset nvram first time
4 hours ago, Gollum said:
how do I create a patch with hackintool please?
https://www.olarila.com/topic/5970-guide-hackintool-video-patch-fast-and-easy-solution/
