HP Envy 15-ED0157NG Ice Lake Touchscreen & Sleep Problems !? I Need Help
Hi my Name is Mark I come from Germany,
I have read my way through the Dortania Guide so far, everything works fine except for 4 minor problems .....
with an i5-1035G1, 16GB memory, Intel SSD, Intel Wifi AX201, Intel Ice Lake
1. He just won't go to sleep no matter what I do
2.ELAN touchscreen "ELAN 2514" just doesn't want to work the I2C Synaptics touchpad works perfectly, even multi
3. The built-in mic does not want to work properly under Ubuntu, the touchscreen also.
4. The display brightness is max 80% "100" only after the idle state is it real 100% totally shit ^^
I've been in the DSDT scene for a long time, but I've always broken my fingers at DSDT, I'm now 1 week's turn but these 4 points don't stand a chance for me.
I hope you can light up my bike. Sorry for my bad English, but the German Hackintosh Scene fell asleep very much and I think you have been the best place to go. You are doing a really MEGA job !! Thank you !!
Wifi and BT Kext i have remove "To Big"
https://www.dropbox.com/s/2gw9doun4idr5s2/Send me MacBook-Pro-von-Mark.fritz.box.zip?dl=0
Many greetings from Germany and Peace
Only the 2 ACPI tables in OC or in addition to the existing ones? No change unfortunately hmm
What problem is this supposed to solve? The touchscreen ?
Thank you for the quick support
save one ioreg with two files above only in acpi folder
Archive.zip
ADD in bootargs
-igfxblr -noDC9 igfxfw=2
reset nvram one time
the problem is not acpi
u need adjust these configs
I don't understand why sleep just doesn't want to, refilled thousands of hours later, the sleep problem must be with the DSDT. With your DSDT from your Lenovo IdeaPad S145 10th Gen IceLake, my HP sleeps strangely or ^^ But I don't understand why maybe because your Lenovo EC0 is patched to EC?
dont use dsdt fro other hardware
