Problems with Audio on Fujitsu Esprimo Mobile D9500
I have a Fujitsu Esprimo Laptop D9500. I had to boot the iATKOS L2 DVD from a USB DVDROM, it wouldn't boot from the built-in one (but all the Windows DVD's did. I installed the PS/2 from the iATKOS and that was all.
I managed to find a kext for the Graphics and also for the Marvel NIC, but the Audio is defying me! In Windows it's a REALTEK ALC262 (an Intel 82801H)
I found an AppleHDA kext on OSX86 and a DSDT HDEF for the alc262. I pasted it in according to the instructions, but the DSDT compiled with errors. a missing DTGP. I added the DTGP file I found on your site, but I still get errors : -
Intel ACPI Component Architecture
ASL Optimizing Compiler version 20110112-32 [Jan 13 2011]
Copyright © 2000 - 2011 Intel Corporation
/Users/tfalconer/Desktop/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 594: If (\_SB.PCI0.HDEF.PMES)
Error 4064 - Object does not exist ^ (\_SB.PCI0.HDEF.PMES)
/Users/tfalconer/Desktop/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 596: Store (One, \_SB.PCI0.HDEF.PMES)
/Users/tfalconer/Desktop/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 1142: Method (_PSR, 0, NotSerialized)
Warning 1088 - Not all control paths return a value ^ (_PSR)
Warning 1081 - Reserved method must return a value ^ (Integer required for _PSR)
ASL Input: - 6715 lines, 225387 bytes, 2626 keywords
Compilation complete. 2 Errors, 2 Warnings, 0 Remarks, 76 Optimizations
Now I'm stuck! Can anyone help me please?
hi
post u dsdt
and the dsdt edit for alc262
to see if can compile it
Not sure how I'm supposed to do this because it won't accept the extension .dsl to attach. I tried .txt. rtf and no extension and they all tell me to bog off.
Please tell me how to post these
