bigsur
Hello, Could you share your efi on github?
I use the newer version of board of biostar b550mh, I tried some different efi and generated own usb map, it didnot work.
I searched the efi about biostar board, there were only few examples. So i hope you can share your efi to help me, I will really appreciate you.Thx
