HP Envy SleekBook 4t mountain lion 10.8 (Installation Guide)
I5 3317U IvyBridge
10GB G.SKILL 1333 (problem with 16GB on this NB)
HD4000 full QE/CE
Webcam works
Audio perfect Vendor ID: 8086 Device id : 1e20 changed in VoodooHDA info.plist
Wifi replaced with AR9280
Doesn't work :
Card Reader
Sleep
as we don't have any option to change in BIOS all locked by HP and we no have any Insyde Bios Unlocked with this model and bios F0a so we have to use some Flag in bootloader to pass USB and wait for root device (AHCI) problems, and CPUS=1 is for paching the lapic kernel
make USB installer with one of them (niresh 10.8, myHack 1.3.2,###### )
Boot with it plugged in USB2 (single left part )and write CPUS=1 USBBusFix=yes ForceHPEToff=yes
Choose your lang , open disk utility partition your HDD
start install it without any customise setting
when install finished again the flags
but this time choose your HDD not USB (i called it ML)
choose keyboard bla bla
when you are in desktop
install the KEXTS you downloaded from the link blow on with KEXT Wizzard
http://www.insanelymac.com/forum/index.php?showtopic=253395
Download Cameleon Wizard from here and make the org.chameleon.Boot.plist and SMBIOS.plist in Extra Folder one the close it and REPLACE my Extra Folder with the old one with all flags ready and full HD4000 QE/CE inside string
http://www.insanelymac.com/forum/topic/257464-chameleon-wizard-utility-for-chameleon/
What you need to download
http://www.sendspace.com/file/xwhci0
http://www.sendspace.com/file/yd59os
VoodooPS2 controller and Trackpad for Synaptics
http://www.osx86.net/downloads.php?do=file&id=3210
FAKESMC if you get KP
http://www.mediafire.com/?lgxtj47kk47cn9k
2 videos to show how it works
Check this thread for problem , Kernel Panics
http://Olarila.com/forum/viewtopic.php?f=27&t=1627
Note:
1.if you have problem with VoodooHDA
http://Olarila.com/forum/viewtopic.php?f=18&t=454
I add modified Info.plist in the folder u download (voodoo hp audio info) with vendor and device id and Control fix already done, replace with mine the info.plist then reboot
2. if you install/remove/modify any kext you have to repair permissions and rebuilding kext caches with KEXT WIZARD
