stormlance Posted September 24, 2012 Posted September 24, 2012 (edited) Hello, guys! My system: Mac OS X 10.8.2 ASRock P67 Pro i5 2400 3.1 GHz ATI HD 6850 1 GB ALC 892 - multishit DSDT (no errors, no warnings) SSDT (patched BIOS + patched AppleCPUPowerManagement.kext 10.7.3 version) Everything is OK now and works fine except: 1. Reboot with "Shutdown monitor has exited" message and then "Killability" e.t.c 2. Display awake from the sleep 3. "Sound Assertion AppleHDA Codec Generic at line 350" message while booting To fix "wake up" in priority. The sleep woks fine but when the system wake up there's no display then. Tried to patch DSDT - no changes, then "darkwake=0" at boot - nothing. NullCPUPowerManagement.kext in S/L/E is removed. What can it be? Attached my DSDT.aml below Please help, i appreciate any suggestions) DSDT.aml.zip Edited September 24, 2012 by Guest
pmdsp Posted September 24, 2012 Posted September 24, 2012 Try the attached DSDT. Stormlance_DSDT.zip ASRock H67M ITX HT, i5 2500K 8GB Ram GB Score - 9815
stormlance Posted September 24, 2012 Author Posted September 24, 2012 Try the attached DSDT. And i almost said "Hallelujah" but... Ethernet don't work after awake...) Any ideas?
pmdsp Posted September 24, 2012 Posted September 24, 2012 Have you got proper Ethernet drivers? I started saving different version as i started editing the DSDT. This attached DSDT i have only done audio and sleep edits everything else is untouched. Stormlance_DSDT_New.zip ASRock H67M ITX HT, i5 2500K 8GB Ram GB Score - 9815
stormlance Posted September 24, 2012 Author Posted September 24, 2012 I have RTL8111e and used http://www.osx86.net/downloads.php?do=file&id=3048 it works fine before the sleep Attached my system log below "PhyWrite fail" message repeat again and again Logs.zip
pmdsp Posted September 24, 2012 Posted September 24, 2012 Remove that kext go to tonycrap and download the latest multishit and Install Lnx2Mac's RealteckRTL81xx Ethernet driver. Hope this helps.. ASRock H67M ITX HT, i5 2500K 8GB Ram GB Score - 9815
stormlance Posted September 24, 2012 Author Posted September 24, 2012 God bless you, man) You were right, the problem was in that kext. Installed a new one and it works perfectly) Thank you)
pmdsp Posted September 24, 2012 Posted September 24, 2012 All the credits goes to this website and amazing people managing it. I saw ASRock in the subject and i jumped straight in help.. ASRock H67M ITX HT, i5 2500K 8GB Ram GB Score - 9815
maclaw Posted August 7, 2013 Posted August 7, 2013 Hello! I also had issues with sleep, but first DSDT file resolved them. But now PS/2 doesn't work, could you help me? Cheers!
