I used the DSDT from this site and patched a bit, everything seems fine now, using native pm and even sleep and wake works. However, i can't wake the system from keyboard or mouse, i thought it might be related to UHCI/EHCI problems but i actually did patched it, could anyone please kindly help look at my DSDT? :cry:
My rig config:
CPU: Intel Core 2 Quad Q8400
MB: GIGABYTE GA-EP45T-EXTREME (BIOS: F5i)
GFX: ATI HD 5870
meattattat, seems like no one replied so i jumped in, I'm not an expert but ill try to edit your DSDT.
Attach the pre-edited DSDT. Since you have already tired patched the DSDT with available patch from the database, ill try to patch it with individual and only imp patches.
If you don't have a pre-edited DSDT extract it on a fresh installation or if you run windows use AIADA64.
i don't understand u post
if the patch is here in database
u want us apply the patch ?
the hard job is donne, so ...
do it
Ok, Here is what i have done so far,
The first DSDT you attached in the beginning of the thread and the original DSDT didn't match so to avoid confusion i have edited first DSDT you attached (beginning of the thread) since you had everything working except wake from sleep using keyboard or mouse.
Audio codes in DSDT are changed if the audio don't work using this DSDT then please download the proper AppleHDA.kext edited for ALC888.
Hope this helps..
meattattat_DSDT.zip
