hello all. having quite a few issues getting this to boot without my USB installer. no combination of multishit seems to work. i made a DSDT file using the MoBo patch posted (this was the closest i got to success), tried with Easybeast. initially getting a "Kernel Panic" from what it seems (not familiar with UNIX commands and such so im blurry on details, here to learn), but i seem to get past that. the most successful attempt so far resulted in an everlasting apple loading screen
my next idea is to attempt to apply each driver through multishit before the separately to see what might be causing an issue. anything else i may have looked over?
my specs
AsRock Z77 Extreme 4
Intel i5 3570k
1TB caviar black HDD
EVGA nVIDIA GTX 660ti
ill get back you on the type of RAM, at school so don't know brand off the top of my head
I am an amateur on this as well. I had a lot of assistance getting my machine running.
That said, I would make sure you do the following if you haven't already:
1. Set your internal graphics memory to 64mb in your bios
2. Do not install your graphics card until you are able to boot off your hard drive into OSX.
With the assistance I received from PMDSP I had a DSDT modified for my system. If you would like I could export mine out and post it here.
File below. From my \extra folder
Thanks cjwescott for sharing the patch. pmdsp also mention about APPLEHDA.kext, can you share it too? It seems that the kext can make you audio (realtek alc898) working. i have the same motherboard as yours.
thanks, sorry, i'm not english speaker
Ethernet: Realtek 8111/8168/8411
HDisk 1: Samsung HD252Hj
HDisk 2: WDC WD20EZRZ-00Z
Hopefully this is the one. APPLEHDA.kext attached.
thank you very much, sorry for late reply, i will try to use this kext and dsdt you provide
