Gigabyte Z490 G with Titan Ridge 2.0 TB adaptor, RX560 and 10 Gbps Aquantia PCIe network card. Problem with TB and OnBoard audio
Dear Maldon.
I have installed Catalina, and this works fine. However I have hardware issue, I cannot get the TB to work and the OnBoard audio to work. The Opencanopy is installed, and the audio chime when entering the boot screen works on the rear green output. But MacOS reports that the Realtek 1220 hardware is there but no driver is loaded.
Also when checking for TB MacOS reports no TB hardware. I checked the bios settings and these should be ok.
Can you recommend things I should try?
Thanks a lot in advance.
Kindest regards
Hans-Henning, Denmark.
