Hi friends, I am new in the macOS and hackintosh world, this is my configuration:
CPU: 11th Gen Core i5 11600K 3.90GHZ (Rocket Lake)
Mother: Asrock Z590 PG Velocita (Wifi)
GPU: RX 570 4GB
RAM: 16 GB
+ Audio Works Fine via HDMI output to Monitor
+ Bluetooth (Works fine and connects)
+ Intel(R) Ethernet Connection (14) I219-V (Works Fine)
+ Killer E3100G 2.5 Gigabit Ethernet Controller (Works Fine)
+ Killer(R) Wi-Fi 6E AX1675x 160MHz Wireless Network Adapter (210NGW) - (NOT working, does not detect any connection)
I downloaded "Big Sur Olarila 11.4 with EFI folder for chipset series 300, 400 and 500", I mounted that image on a pendrive and installed it, also I downloaded the file "EFI OpenCore Serie 500. zip" and replace it with the original, I already load the OS from the hard drive but I have so far 2 problems, my Wifi network is not recognized, I can only use the internet via LAN cable, and I want to remove the white letters (like a debug mode) that load at startup before loading the MacOS logo, I do not know how to remove those letters and only load the progress bar and the Mac logo.
I can solve these problems, I have to redo the installation in a different way, thank you very much for your attention.
5 hours ago, MaLd0n said:
intel wifi https://github.com/OpenIntelWireless
remove -v from bootarg and reset nvram
thanks for replying, I am building a new installer with a new efi configuration, I am basing it on the efi folder that you shared (EFI OpenCore 500 Series. zip)   and all the kets files are there.
with ProperTree I loaded the config.plist file and hit the options OC Snapshot and then clean Snapshot, it added all the kets and they are sorted as follows....
<plist version="1.0">
<dict>
	<key>Add</key>
	<array>
		<dict> (0)
			<key>BundlePath</key>
			<string>AtherosE2200Ethernet.kext</string>
		</dict>
		<dict> (1)
			<string>FakePCIID.kext</string>
		</dict>
		<dict> (2)
			<string>FakePCIID_Intel_I225-V.kext</string>
		</dict>
		<dict> (3)
			<string>IntelBluetoothFirmware.kext</string>
		</dict>
		<dict> (4)
			<string>IntelBluetoothInjector.kext</string>
		</dict>
		<dict> (5)
			<string>IntelMausi.kext</string>
		</dict>
		<dict> (6)
			<string>itlwm.kext</string>
		</dict>
		<dict> (7)
			<string>Lilu.kext</string>
		</dict>
		<dict> (8)
			<string>LucyRTL8125Ethernet.kext</string>
		</dict>
		<dict> (9)
			<string>RealtekRTL8111.kext</string>
		</dict>
		<dict> (10)
			<string>RestrictEvents.kext</string>
		</dict>
		<dict> (11)
			<string>RTCMemoryFixup.kext</string>
		</dict>
		<dict> (12)
			<string>SmallTreeIntel82576.kext</string>
		</dict>
		<dict> (13)
			<string>USBInjectAll.kext</string>
		</dict>
		<dict> (14)
			<string>VirtualSMC.kext</string>
		</dict>
		<dict> (15)
			<string>WhateverGreen.kext</string>
		</dict>
		<dict> (16)
			<string>XHCI-unsupported.kext</string>
		</dict>
		<dict> (17)
			<string>AirportBrcmFixup.kext</string>
		</dict>
		<dict> (18)
			<string>AppleALC.kext</string>
		</dict>
		<dict> (19)
			<string>SMCProcessor.kext</string>
		</dict>
		<dict> (20)
			<string>SMCSuperIO.kext</string>
		</dict>
	</array>
</dict>
</plist>
is it correct this way?, thank you very much
edit: well I just watched a video tutorial and I have all the necessary kets, I just need to run the HeliPort.dmg application to activate the wifi connections, I'll test it now...
Edited by LuigBren
