[Solved] Fonts issue after update from BS 11.2.2 to BS 11.4
Hello fellas,
I have an issue with my HACK. After update from Big Sure 11.2.2 to Big Sure 11.4 I have problems with fonts in various applications.
My specification:
CPU: I7-6700
RAM: 24 GB 2400MHz
iGPU: HD530 (disabled)
dGPU: Gigabyte RX 5700 XT 8GB OC
Motherboard: Asrock Z170 Pro 4s
WiFi : Fenvi T919
LAN: I219V
Bootloader: OpenCore 0.7
I will attach my EFI without SN.
USB Map solution from this solution
No issue Big Sur 11.2.2
Issue Big Sur 11.4
EFI.zip
Edited by PituPitu
I tried everything related to smooth fonts. Also the tutorials related to image scaling did not help.
I also put the hack based on the iMac17.1 SMBIOS with iGPU enabled. It didn't help either. Maybe you have some other idea?
