Gemini Saga Posted June 16, 2021 Posted June 16, 2021 Good Evening, I'm trying to install big sur 11.4 with Opencore as bootloader, but i'm stuck at the same screen over and over again, no matter which boot-args i use. The main error is "Waiting on <dict ID="0"><key>IOProviderClass</key>..." I've got only USB 3 ports in my Mobo, tried as well use my monitor's USB 2.0 hub but to no avail. As i did not find an EFI specific to my Mobo, i used the one avaliable on the link below https://www.tonymacx86.com/threads/guide-macos-big-sur-11-on-z390-aorus-elite-board.306236/page-13#post-2257221 Sorry if i did not do things as i should, it's my first time here. My Specs: Mobo Gigabyte Z 390 GAMING SLI Processor Intel Core i5 9400F VGA Gigabyte RX590 gaming rev 2 SSD 240GB SATA Corsair 16GB RAM 3200mhz Thank you!!! Errors.zip
Administrators MaLd0n Posted June 16, 2021 Administrators Posted June 16, 2021 use olarila folder. dont lose time with this files above https://tinyurl.com/y7puzwv9 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Gemini Saga Posted June 17, 2021 Author Posted June 17, 2021 (edited) Thank you MaLd0n for your help, used olarila's EFI but now i'm stuck at PCI CONFIGURATION BEGIN. Just modified the Serial, Board Serial and SmUUID as per guide. It did not work so i added the following boot args separately: (kept the boot args from the config.plist) UseKernelCache=No npci=0x2000 -f -v -v PCIRootUID=1 npci=0x2000 -v -x -graphicsenabler=yes https://im.ge/i/TZ4ZW https://im.ge/i/TZnwr There's something else i'm missing? Edited June 17, 2021 by Gemini Saga Forgot
Administrators MaLd0n Posted June 17, 2021 Administrators Posted June 17, 2021 dont change nothing bios/uefi in default just disable csm reset nvram one time -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Gemini Saga Posted June 18, 2021 Author Posted June 18, 2021 Hello there, Dear MaLd0n, just did as you say, progressed further but stopped with these new errors: https://im.ge/i/oESjphttps://im.ge/i/oEdWPhttps://im.ge/i/oE2Oqhttps://im.ge/i/oEOzC There's something i can do to fix it?
Administrators MaLd0n Posted June 18, 2021 Administrators Posted June 18, 2021 use usb 2 port set sata to haci in bios/uefi setup -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
