Hello good afternoon!
I recently managed to install big sur on my HP notebook. I followed the steps of the Dortanias OC guide to create OC and managed to make an EFI that works. However, with the system installed, there are some major bugs. The main one, which I would like to help, is the sound. I'm muted! I've tried AppleALC, VoodooHDA, tried to change the id and nothing.
Follow RunME and Ioreg for analysis.
HP Envy 4 NoteBook
core i5 3317U
Intel HD 4000
IDT92HD91BXX audio
https://www.mediafire.com/file/k4dpqxfm3wj4wnw/Send_me_MacBook-Air-de-Edson.zip/file
https://www.mediafire.com/file/g4jjlmasvcefgh3/MacBook-Air-de-Edson.ioreg/file
ok, I had already visited the links you placed, mainly audio solution. as I said in the first post, I already tried to change the id, with alcid with all the ids mentioned in the OC installation guide. but I have not had success with any.
thanks for your help.
HP Envy 4 NoteBook
core i5 3317U
Intel HD 4000
IDT92HD91BXX audio
Pls share for me EFI folder. Thanks
