SLEEP/Hibernate not working on ice lake big sur i3 1005g1
everything from igpu to trackpad works only sleep issues
@MaLd0n can dsdt patch would solve sleep fix??
before extract this dump u need remove all acpi renames
i donot get it what renames should i remove all patches
extract new sendme after remove and reboot
DSDT.02.zip
let me check ur full efi folder
try. test this efi
EFI.zip
reset nvram one time
2 hours ago, prabhat04 said:
how to reset that as only big sur is seen tested the efi it loads but sleep wake call not work
resetted nvram but same black screen i think display not load after wakeup call
try with my video patch. work nice
Quote
            <dict>
                <key>AAPL,GfxYTile</key>
                <data>AQAAAA==</data>
                <data>AQBcig==</data>
                <key>device-id</key>
                <data>XIoAAA==</data>
                <key>enable-cdclk-frequency-fix</key>
                <key>enable-cfl-backlight-fix</key>
                <key>enable-dvmt-calc-fix</key>
                <key>framebuffer-fbmem</key>
                <data>AACQAA==</data>
                <data>AAAwAQ==</data>
                <key>framebuffer-unifiedmem</key>
                <data>AAAAwA==</data>
            </dict>
thats cool patch increase vram to 3 gb instead of 2 gb and sleep wake fixed but now when i used new efi wifi is showing networks but not connecting i am using intel ac 9461 using airpotlwm.
Dusting off my Olarila account to say that this ig-platform-id fixed wake from sleep for my HP 14-dq1033cl (i5-1035G4) as well! Thanks a bunch!
