Hello everyone,
I've succeeded at installing MacOS Big Sur on my computer and for the most part, it works great!
I've got one big issue however that I can't seem to resolve.
I have two GPUs on my computer, a RTX3080 fe on the first PCI-E SLOT (x16) for gaming in Windows and a rx480 4go on the second for MacOS.
I can't disable my RTX3080 fe and I need to do it because it prevents my computer to sleep normally.
When it is installed on my computer, my computer takes a super long time to sleep and wake up from sleep.
I've tried bot methods explained on the dortania guide:
DeviceProperties Method
PciRoot(0x0)/Pci(0x3,0x1)/Pci(0x0,0x0)
name	data	23646973706C6179
IOName	string	#display
class-code	data	FFFFFFFF
But the gpu is still there when I reboot.
SSDT Method
I've found the PCI-E path on windows (Location path) and converted it as explained. It gave me this result :
_SB_.PCI0.GPP8.GFX1
And here's my Spoof-SSDT.dsl:
DefinitionBlock ("", "SSDT", 2, "DRTNIA", "spoof", 0x00000000)
    External (_SB_.PCI0.GPP8.GFX1, DeviceObj)
    Method (_SB_.PCI0.GPP8.GFX1._DSM, 4, NotSerialized)
        If ((!Arg2 || !_OSI ("Darwin")))
            Return (Buffer (One)
                 0x03
        Return (Package (0x0A)
            "name",
            Buffer (0x09)
                "#display"
            "IOName",
            "#display",
            "class-code",
            Buffer (0x04)
                 0xFF, 0xFF, 0xFF, 0xFF
But it also doesn't work.
Finally, I found on a german forum that if I add the following entry to my config.plist, it's now working but the boot time of my Hackintosh is very slow (2,3mn) :
device_type	string	VGA compatible controller
What could be the issue here?
I've spent litteraly the entire night browsing google to try to find an answer but nothing, hence why I'm turning to you.
I've attached my RunMe-Output folder
Thank you for your help!
Send me Nicolass-Pro.lan.zip
u need post one ioreg too
remove all ssdts
add only dsdt
select Rebase Regions in acpi tab
reset nvram one time
Thanks a lot but it doesn't work. I've added the DSDT, deleted the other, activated Rebase Regions and reseted mvram but it reboot during the boot process (with the apple logo)
amd is set to primary gpu in bios/uefi?
CHECK IF WORK
DSDT.02.zip
the device is missing inside gpp8
i create one gpp8/pegp with _adr 0 and disable this disable. in this case disable pegp inside gpp8
if disable entire gpp8 cause this problem. common in some cases
