Greetings Maldon, using your Coffee Lake EFI (OC), the system has completed installation successfully. Any assistance in DSDT patching would be most appreciated. Thank you very much!
Gigabyte Z390 Aorus Ultra
Intel i9-9900k
Radeon RX480
Big Sur 11.0.1
OC 0.7.0
Send me Bigs-Mac-Pro.zip
macpro7,1 with no IGPU enable
Enjoy!
16 minutes ago, MaLd0n said:
Enjoy!
Thanks for your patience..Presently none of my USB 3 ports are recognized by USB 3 external drives.  Any advise would be most appreciated. Thanks again.
if u use 11.0.1 just enable xhci patch and remap all
this procedure is just for 11.3+, xhci patch stop work
Will update to 11.3, thanks so much
After updating to 11.4 and OC 0.7.0, i'm still not seeing any SS ports when attempting to map USB3.0. This is a 300 series board, would that make a difference? Thanks for your patience sir.
let me check efi folder
https://easyupload.io/kz86aj
start remap
u need use this version of usbinjectall, dont change
after reboot clear usb tab in hackintool
start remap
I sure appreciate your patience here. I used this EFI and after mapping USB2 for the first stage, the system often will not boot to desktop. (please see pic). When it does and I refresh with Hackintool to map USB3, there are still no "SS" ports. Thanks again.
ssprod.zip
no idea what happens
chewck if have other efi folder in some efi partition, boot from ssd with no usb connect
remap is easy, just need some patience after 11.3
Greetings Maldon! System was working well, however I've added a Titan Ridge 2 Thunderbolt card and can confirm functionality. The issue now is that my system freezes and reboots after 5 minutes of booting up. Any suggestions as to why this is happening? It's been running perfectly prior to adding the card. I've made sure to set Thunderbolt in the bios to the appropriate settings. Much appreciated!
IMG_8268.JPG.zip
Edited by ssprod
this problem is nvme
what nvme model
what nvme model
Thank you for your patience. Samsung EVO+ 970 M.2. When I remove the Titan Ridge 2 card, system runs normally.
