Hi there everyone,
so I downloaded the pre-made Mojave Image from
and used Balena Etcher to write it to a 16GB pendrive , now after restarting ,in the Select Boot Device menu the pendrive with Mojave is not visible.
I've tried using all usb ports,
here are my specs : https://del.dog/ubacamubif.txt
I tried the same usb in another laptop but it was recognised so what am I doing wrong here? any help will be appreciated!
Hi there thank you for replying, but the problem is I haven't installed macos yet , the usb with bootable os doesn't boot into clover.
from what I understand am I supposed to install opencore over clover? or is the Intel 2120 not supported?
Thank you, so I started from scratch and used RecoveryImage.dmg and added all kexts and 3 drivers openRuntime.efi opencanopy.efi and hfspluslegacy.efi .
when I boot oc gives error OCB: LoadImage failed - Unsupported
So I turned JumpstartHotPlug = Yes, but even then the same error occurs
I've attached config.plist and the opencore logs
config.plist.zip opencore-2021-06-17-174957.txt.zip
use olarila images
why need recovery
Hey admin, I'm getting the same error that my drive isn't showing up in the boot menu after everything set up properly. I've used olarila comet lake notebook efi and trying to install mojave
