Help Kext on laptop toshiba Slow leopard 10.6
How to fix wifi & Lan on SL 10.6 Laptop Toshiba Satellite L310 CPU T3400 Pentium dual core 2.16ghz, chip GL40 45 series express family chipset card onboard, wifi Atheros AR5007EG Vendor id: 168c, device: 001c, card Lan marvell yukon 88E8040T Vendor: 11ab, device id: 4355
Anyone can help me ? tks
Best Regards,
Andry Tran
hi
try to see this and update u snow
http://www.insanelymac.com/forum/index.php?showtopic=155935&st=140
man u have a problematic network config, about wifi , or use a usb wifi or change the card for a compatible one, is the few things u can replace in a notebook.
