1 hour ago, RandomTech7 said:
thank you Just installed Monterey Beta on my Laptop and it looks stable with my fav Apps, i'm keeping it :)
Thanks! now looks nice ?
One question, on opencore boot screen my laptop keyboard always not working, but on macOS is working good.
is there fix for that?
Hack Pro: Asus Strix Z590i, i9-11900K, RX 6900 XT, 1TB Samsung QVO SSD, RAM 16GB Corsair RGB @3200Mhz (Big Sur) OC
Hackbook Pro: (MSI GE63 Raider RGB) i7-8750H, Intel UHD 630, GTX1070 8GB(disabled), 16GB RAM @2666Mhz (Big Sur) OC
is not Olarila folder
check ur procedure
How can I find the right folder for my Inspiron 7460
Any help please?
I've been trying to do hackintosh for 2 months
any component its compatible with Hackintosh
and i am very bad on this things
thankful!
Hi Maldon,
Currently, Windows is the first boot option in my picker and macOS is the second. Can I ask you how I am able to make macOS the first and Windows the second?
19 minutes ago, FlashSn0w said:
Hi Maldon
press ctrl and set macos to primary on boot screen
Check opencore manual
Enjoy
7 minutes ago, FlashSn0w said:
I can’t find anything on google that can help me. Can you tell me?
no idea
-Bios Configuration --> Disable CSM / SATA Mode AHCI / If need disable Secure Boot
-UEFI Mobos just paste EFI folder into EFI partition
-OpenCore MOD EFI folders HERE
-Tutorial
-Glossary Kexts
AirportBrcmFixup.kext - An open source kernel extension providing a set of patches required for non-native Airport Broadcom Wi-Fi cards.
AppleALC.kext - An open source kernel extension enabling native macOS HD audio for not officially supported codecs without any filesystem modifications.
AtherosE2200Ethernet.kext - Atheros onboard LAN driver for macOS.
CpuTscSync.kext - It is a Lilu plugin, combining functionality of VoodooTSCSync and disabling xcpm_urgency if TSC is not in sync. It should solve some kernel panics after wake.
ECEnabler.kext - Allows reading Embedded Controller fields over 1 byte long, vastly reducing the amount of ACPI modification needed for working battery status.
FakePCIID_Intel_I225-V.kext - Intel onboard LAN driver for macOS. Need FakePCIID.kext.
IntelMausi.kext - Intel onboard LAN driver for macOS.
Lilu.kext - An open source kernel extension bringing a platform for arbitrary kext, library, and program patching throughout the system for macOS.
LucyRTL8125Ethernet.kext - Realtek onboard LAN driver for macOS.
RealtekRTL8100.kext - Realtek onboard LAN driver for macOS.
RealtekRTL8111.kext - Realtek onboard LAN driver for macOS.
RestrictEvents.kext - Lilu Kernel extension for blocking unwanted processes causing compatibility issues on different hardware and unlocking the support for certain features restricted to other hardware. The list of blocks currently includes:
/System/Library/CoreServices/ExpansionSlotNotification
/System/Library/CoreServices/MemorySlotNotification
/usr/libexec/firmwarecheckers/eficheck/eficheck
RTCMemoryFixup.kext - An open source kernel extension providing a way to emulate some offsets in CMOS (RTC) memory. It can help you to avoid some conflicts between osx AppleRTC and firmware/BIOS of your PC.
SmallTreeIntel82576.kext - Intel onboard LAN driver for macOS.
USBInjectAll.kext - Basic USB Solution
VirtualSMC.kext - Advanced Apple SMC emulator in the kernel.
VoodooPS2Controller.kext - New VoodooPS2Trackpad uses VoodooInput's Magic Trackpad II emulation in order to use macOS native driver instead of handling all gestures itself.
WhateverGreen.kext - Lilu plugin providing patches to select GPUs on macOS.
Credits:
  • Like 2
  • Thanks 2
4 hours ago, Geoff Agnew said:
DSDT.aml.zip looking for your skills plz I think this is what you needed
Post one Full Dump
https://olarila.com/files/Utils/RunMe.app.zip
and one Ioreg
https://olarila.com/files/Utils/IORegistryExplorer.app.zip
