Possible to use Internal and external GPU at same time?
Hey guys...I'm new here, sorry if the post has something wrong.
Lets start; I have a desktop PC that I use Windows, personal computer. Want to install hackintosh with dualboot to work on MacOS, and saw a guy using a EFI that could work to me, but there's a problem...My PC config:
i5 10400
B460M Aorus Pro
16GB (2666)
SSD 120GB + SSD 512GB + 1TB HDD
And here comes the problem...
I have a RTX3060TI.
I know that my GPU is not compatible with any MacOS version...but the internal graphics HD630, i saw that may work well...
My doubt is: Can I make MacOS work with the intel gc, without removing my 3060ti?
My idea is to make a dual-boot, using my RTX on windows, and the HD Graphic card on Mac; plug 2 display ports, one for the windows, one for the hackintosh...
Is there any chance for it to work?
Thanks, guys.
yes
need disable this nvidia via tables and use igpu
I've added the -wegnoegpu on boot args, but when i try to start macos install i got this error:
support.apple.com/mac/startup
Someone knows what to do?
IGPU is primary GPU in bios/uefi?
