Hey guys.
Today I upgraded Big Sur from 11.3 to 11.4 and the upgrade went smoothly.
But when I entered the system, the wireless key and mouse could not work, which was caused by the unrecognized USB2.0 port when I checked.
I connected to the system using VNC and found in Hackintool that all the USB2.0 ports were not working,USB3.0 works at 5 Gbps.
I followed the instructions to disable XHCIPortLimit. All ports work, but USB flash drives on USB 3.0 ports only work in 480 Mbps mode.
I tried to customize the ports through Hackintool, but after customization, only USB2.0 will work. I can find many HS ports in Hackintool, but only one SS port. Other USB 3.0 ports do not recognize both 2.0 and 3.0 devices.
How should I solve this problem?
Thank you.
