SamBox436 Posted June 4, 2021 Posted June 4, 2021 Hey guys I got a new computer and the specs are... Intel UHD Graphic 630 10th gen Intel core i3 Factory Build Windows 10 A Zip file will tell you the problem. Images.zip
Administrators MaLd0n Posted June 5, 2021 Administrators Posted June 5, 2021 use usb2 port and after remap ur usb https://www.olarila.com/topic/14220-video-guide-usb-port-mapping-guide-2021-bigsur-113-with-no-xhci-port-limit/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
SamBox436 Posted June 5, 2021 Author Posted June 5, 2021 Thanks for the tip I will try that. But 2 problems. 1. I am using Windows 7. 2. I don't see a EFI Partition on the USB.
anto barreca Posted June 5, 2021 Posted June 5, 2021 https://www.olarila.com/topic/12857-how-to-mount-efi-partition-on-macos-or-windows/
