HP Z840 - Dual Xeon E5-2698 v3 - CPU Power management issue....
Hi there !
This new setup is giving me a hard time around CPU power management and therefore I have sub-optimal performances.
I had to manually finish the sdl out of ssdtprgen because it would fail compiling for more than 16 cores... (see sdl attached)
I read that CPUPM aml were broken for X99 so I used CPUFriend kext to "load" it.
At boot I run into "There are 0 entries in the linked list before target" and X86PlatformShim::start - Failed to send stepper.
Checking ioregistry X87PlatformSHim is attached, AppleACPICPU attached to all core and showing ct-frequency-data...
sysctl -n machdep.xcpm.mode is "1" but vector_loaded_count is 0...
I'm out of ideas end spent way too much time on this,  so I came here seeking help ! :)
(I installed using opencore guide for Haswell-e and their premade SSDTs. It booted in a couple of hours but I've been trying to solve XCPM for 2 weeks !!
Still using the default dsts except that I modified SSDT-PLUG for dual cpu. (Not sure it was needed though)
I hope we can fix it !
Thanks in advance,
Send me Xaviers-iMac-Pro.zip 2CPUs_64cores_CPUFriend.dsl SSDT-PLUG-XRR.aml
1- from OpenCore manual
Note 3: For XCPM support it is recommended to use the following combinations.
Haswell-E (0x0306F2) to Haswell (0x0306C3):
Cpuid1Data: C3 06 03 00 00 00 00 00 00 00 00 00 00 00 00 00 Cpuid1Mask: FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00
Broadwell-E (0x0406F1) to Broadwell (0x0306D4):
Cpuid1Data: D4 06 03 00 00 00 00 00 00 00 00 00 00 00 00 00 Cpuid1Mask: FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00
2- OC have good quirks
AppleXcpmExtraMsrs
Description: Disables multiple MSR access critical for certain CPUs, which have no native XCPM support.
This is typically used in conjunction with the Emulate section on Haswell-E, Broadwell-E, Skylake-SP, and similar CPUs. More details on the XCPM patches are outlined in acidanthera/bugtracker#365.
AppleXcpmForceBoost
Description: Forces maximum performance in XCPM mode.
This patch writes 0xFF00 to MSR_IA32_PERF_CONTROL (0x199), effectively setting maximum multiplier for all the time.
Apply a fakecpuid for ur cpu and select these quirks. check result
Others things (if don't work with solution above)
have several Kernel patches for x99
need some some for check what best result
Quote
<dict>
                <key>Arch</key>
                <string>x86_64</string>
                <key>Base</key>
                <string></string>
                <key>Comment</key>
                <string>xcpm_core_scope_msrs (c) Pike R. Alpha Modify By N.Mano 11.3</string>
                <key>Count</key>
                <integer>0</integer>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>MdLo3U0BAA==</data>
                <key>Identifier</key>
                <string>kernel</string>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <key>MaxKernel</key>
                <string></string>
                <key>MinKernel</key>
                <string>20.4.0</string>
                <key>Replace</key>
                <data>MdKQkJCQkA==</data>
                <key>ReplaceMask</key>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string></string>
                <key>Comment</key>
                <string>_xcpm_pkg_scope_msrs  Modify By N.Mano 11.3</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>MdLoyiL//w==</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <key>Replace</key>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string></string>
                <key>Comment</key>
                <string>_xcpm_SMT_scope_msrs #1  Modify By N.Mano 11.3</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>vgYAAABd6QgAAAA=</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <key>Replace</key>
                <data>vgYAAABdw5CQkJA=</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string></string>
                <key>Comment</key>
                <string>_xcpm_SMT_scope_msrs_2  Modify By N.Mano 11.3</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>MdLoLv3//w==</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <key>Replace</key>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string></string>
                <key>Comment</key>
                <string>__xcpm_enable_pstate_patch  Modify By N.Mano 11.3</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>QcHmCElj1onQSMHqIA==</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <key>Replace</key>
                <data>QcHmCLgA/wAAMdKQkA==</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string></string>
                <key>Comment</key>
                <string>xcpm_bootstrap_HASwell_E (c) Pike R. Alpha Modify By N.Mano 11.3</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>jUPEPEJ3Ig==</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <key>Replace</key>
                <data>jUPBPEJ3Ig==</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string></string>
                <key>Comment</key>
                <string>xcpm_bootstrap Skylake-X/Cascade Lake-X  Modify By N.Mano 11.3</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <key>Replace</key>
                <data>jUO9PEJ3Ig==</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string></string>
                <key>Comment</key>
                <string>xcpm_bootstrap Broadwell-E  Modify By N.Mano  11.3</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <key>Replace</key>
                <data>jUO8PEJ3Ig==</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string></string>
                <key>Comment</key>
                <string>xcpm_bootstrap IvyBridge E  Modify By N.Mano 11.3</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <key>Replace</key>
                <data>jUPGPEJ3Ig==</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string></string>
                <key>Comment</key>
                <string>xcpm_bootstrap Comet Lake  (I9-10980HK) 0x0A0652 Modify By N.Mano 11.3</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <key>Replace</key>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string></string>
                <key>Comment</key>
                <string>xcpm MSR Patch 4206  By N.Mano 11.3</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>QgYAANwzBgAAAAAAAAAAAB8AAAAAAAAAGAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <key>Replace</key>
                <data>QgYAAAAAAAAAAAAAAAAAAB8AAAAAAAAAGAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string></string>
                <key>Comment</key>
                <string>xcpm support /0x82D390/MSR_PP0_POLICY 0x63a  Modify By N.Mano  11.3</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>OgYAANwzBgAAAAAAAAAAAB8=</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <key>Replace</key>
                <data>OgYAAAAAAAAAAAAAAAAAAB8=</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string></string>
                <key>Comment</key>
                <string>Disable panic kext  +0x7700 Modify By N.Mano 11.3</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>igKEwHQN</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <key>Replace</key>
                <data>igKEwOsN</data>
                <data></data>
                <key>Skip</key>
            </dict>
This ssdt looks good SSDT.aml.zip but with x99 we stay need kernel patches
Thanks MaLd0n,
ForceBoost is working, but that's a bit "cheating" ;) I can reach Max Turbo though! I guess it's not efficient while idle though.
I'll try the patches,
Do we know allready if the xcpm_core_scope_msrs patches you sent are working with Big Sure?  Are they all for Haswell-e ?
Should I try them one by one or all at once ?
And in this case should I suppress CPUFriend and associated data while testing ?
Thanks again for your help,
** Update:
I picked iMac15,1 as an smbios because it was the recommanded haswell one. For some reason changing the smbios to MacPro7,1 (while using Cpuid) improved things : CPUs running coller and more steady, improved benchmark by a big margin... it also solved Netflix in safari not running issue.
Edited by xrr
with quirks need test with any extra
x79 and x99 dont have a perfect pm. several things, apple changes after updates. only problems
MacPro7,1 is the best smbios for "new" hardwares
I don't know why it's better with the MacPro7,1 smbios for my Haswell-e but believe me it solved a lot of issue (DRMs, CPu runnning better and cooler). Maybe something related to Desktop vs iMac settings.. Not sure if it's the best though, I'll try others like iMacPro1,1 and MacPro6,1 just in case...
+12% single core and best multi-scores (by small margin)
Check the first 3 results (same settings just changing the smbios)
https://browser.geekbench.com/user/321358w
For now It might not be perfect PM but quite satisfactory... :)
Edited by SpacemanSpiff
