Hai Maldon, Hai Everyone, i have Dell 3050 Micro With Spesification
CPU Dell core i5 7500T 2.70 Ghz
MotherBoard Intel B250 (6W)
IGPU Intel HD Graphic 630
Sound Intel HDMI Audio
Realtek HD Audio ALC255
Ethernet Realtek RTL8168-8111
etc Intel Management angine Interface
Sata Controller Intel/DesktopWorkstation/Server SATA RAID
USB3.0 Controller Intel Extensible
Toshiba Bluetooth Radio
I have 2 problem,
1. Sleep. i read on forum this is common problem on HD630 and this problem doesn't bother me and i can accept it, i use amphetamine to handle it.
2. Microphone. before, I solve this problem with ComboJack on github, until cleanmymac delete that patch and tell the program is malware. i tried install jack fix and i stuck on writing on system partition, i use dortania tutorial and failed (Screenshoot). i have dsdt from maldon but that doesn't make it work.
can anyone help me to patch the microphone cz i need that for my headset to online meeting, or tell me where I went wrong so I can fix the microphone or i can writing on system partition.
EFI : https://we.tl/t-HdPyRDnMcC
ERROR SREENSHOOT on Writing Partition : https://we.tl/t-y3boPu5SrY
IOREG : https://we.tl/t-6POVTwCOJo
SendME : https://we.tl/t-GO6HCiAFqz
THX BEFORE.
Hi maldon, Thx for your reply,
I tried and test layout 3, 11, 13, 15, 17, 18, 20, 21, 27, 28, 29, 30, 31, 66, 71, 86, 99, 100 for ALC255 and problem still not solved. do you have another way to fix my microphone problem.
Thx Before.
u can try with voodoohda
