HP Pavilion boot High Sierra problem
Hi guys, I'm installing on a 2013 High Sierra HP Pavilion 15 (or trying).
The computer has an i5 3337u (Ivy Bridge), 8GB of RAM, a GT 630m from NVIDIA.
I have installed the High Sierra on a PenDrive 3.0 (the fastest port I have is 3.0). To start it as I have not yet installed the Clover I use the installation pendrive but the problem I have is that I cannot start it on a 3.0 port. However in a 2.0 yes, but at such a slow speed that it makes it unusable.
In BIOS I have ports 3.0 enabled, virtualization removed and CSM enabled.
I don't know if it will be due to the file system, or some other problem.
Greetings and thank you very much in advance.
ur usb3 is intel?
