I continue with the problem of the battery not charging (after restarting EC / CMOS Reset) it is composed but when disconnecting and reconnecting it no longer charges I hope and can you help me please thank you.
DSDT.aml
use this kext with vurtualsmc with battery plugin
ECEnabler.kext.zip
this kext work for all
dont apply battery patch and use last lilu + ecenabler + battery virtualsmc plugin
I get the same result (I start the system, I have a battery and charge reading, but when I disconnect the adapter and connect it, it no longer charges the battery) I bought another battery and I continue with the failure .. thanks Mald0N ..
let me check efi folder
use this config, remove dsdt, reboot, extract new sendme
config.plist.zip
wrong sendme
delete old sendmes in desktop and extract new
post ur efi folder too
post ur full efi folder here
i need full efi bro
i need check many things
hi maLd0n I found a DSDT with the patches that make the status of my battery work correctly (it is not a DSDT of my laptop) but it is of the same brand and very similar model. my question is if i could take those patches and implement them on my dsdt or supplement that same dsdt? thanks for all the work.
DSDT.aml
