Clover Problems with system freezing when using charging adapter sometimes without
Hello miss/mister,
I have a problem that my system freezes and shutdown sometimes, could it be some kext files that are not compatible. I attached my clover EFI files. Please help. What can i do to prevent a system freeze. Do i have too many kext files or am i missing one? The rest works perfect except the freeze and shutdown sometimes. Something to do with the voltage maybe? I know some about it but not how to fix it. Thanks in advance.
Could it be possible because i never changed bios settings?
I can pay 10 euro's to the one fixes it with paypal.
PERFECT EFI WITH VRAM BRIGHTNESS BATTERY SOUND.zip
12 hours ago, shh said:
Hello miss/mister,
Changing Bios settings didn’t work. I am now testing if it does’nt freeze without charging cable.
I have a feeling that its the wifi usb that i have “TP-Link” - “TL823N”
i installed the driver version 3 but this is version 2 usb wifi but the V2 driver doesnt’ work on Catalina.
tips? Hints?
please help this is the last thing that needs to be fixed
I am now busy trying to install wifi intel kext hope it works
use debug=0x100 and keepsyms=1 and check if appear info about kp
I fixed it for now i googled every kext and deleted the unnecarry thanks. Keep the post open i will test more.
I will send my new kext files. I cleaned everything. How do i view the debug and keepsyms. I don't know what it is can you cleariffy. I can send money to your paypal account but i don't know how. It keeps more time without freeze though. I also have Intel power management so i can send screenshots or record my screen and you can see how it crash freezes.
The last thing i did was download something old from the app store and something else on the same time. Here are my new kext files in the attachments.
PERFECT EFI.zip
@MaLd0n I think it has to do with the ACPI patched folder files. I tried to fix it because if I run it without GPU support it won't freeze. How do I fix this bro? I can send you money how much is enough for to fix this? Can I send you private messages? I am now running the config_last_running.plist (without GPU support) and the plist that crashes is config.plist(which does have the GPU support)
Edited by shh
I donated 25 dollar with email: giopaez@live.nl
If it is fixed I will donate more. I will send the file to "danielnmaldonado@yahoo.com.br" (max size) with proof I have payed.
@MaLd0n I sended the email now. Now what sir? thanks for your time
@MaLd0n Let me know how late I am gonna play a game on Windows now. Thanks for your time sir. Email me when your ready and I will come.
Edited by shh
