Hey guys i have tried almost every possile thing to build this Hackintosh but i got stuck here i have tried with EFI folders  from Olarila not even start the installation i am attaching my Origin folder
Thanks in Advanced
CPU is i7 4790k and GT 740 GPU
Asus z97 Sabertooth Mark 1 .jpeg.zip
origin.zip
Edited by Dec_Bra1n
HackBook Pro :-HP DV6-6121 TX (Win 10 Pro + macOS 10.13.6 + OC )
Hac Pro:-GA-B365-D3H, Core i5 9440F AMD RX 580 8 GB (Win 10 Pro + macOS 10.15.7 + Big Sur Beta )
Hac Pro:-z97 sabertooth mark 2, Core i7- i7 4790k with GT 740 2GB and 32 GB Ram (OC+Catalina)
iHack:- Assus M2N68-AM-SE2,AMD Athlon+LE-1640,250 SSD ,4GB DD3 800MHZ Nvidia 9400GT (win 10 and 10.9.5+10.10.5)
iHack:-GA875M-D3H ,core-i5 3250,NVDIA 610-2GB 27"LED,8GB DDR3 1600mhz, (Only 10.10.5+10.11.6 with CLOVER)
iHack:-GA-78LMT-S2PT ,AMD Phenom II-X2 560,Radeon 6770 1 GB ,onboard Radeon HD 3000 not tested 4 GB DDR-3 1333 MHZ (10.11.6+Win 10 pro) Special thanks....  To Genius donovan6000 For Mode Bios (WiFi +BT Whitelist removed) & Amazing Hackintosh Guides and tutorial and much more visit this blog Hackintosh Mumbai
wait some time and check if error is "stall"
No errors come stuck there only :(
Thanks @MaLd0n The issue is resolved by removing my FireWire adaptor as it cause the trouble see the sscreenshot so when i removed the card issue got resolved.spacer.png
Thanks Again My Friend.
ye
is a "stall" problem ;)
