Hi there legacy user here I run a bootinstall command in order for me to boot macos bigsur without usb installer. Successfully generated a boot file however the problem is the boot file did not save at the right location which is EFI partition of the system..instead it saves on the EFI partition of usb stick..copying the boot file usb to system did not work any ideas thanks
opencore or clover?
