Stuck with install Mac Big Sur 11.3 with EFI folder for chipset series 300
Hi,
I am using same BIOS params than Bug Sur 11.2.3
I am trying to do a clean install of 11.3 with vanilla image flashed to 16go USB drive
I am stuck then get a scambled screen with "Still waiting for root device !"
Here is a screenshot.
Any idea ?
My rig : Asus Prime Z370-a + last BIOS + i7 8800 coffeelake + 16Go RAM + GTX 1060 + SSD intel
Edited by temis01
Hi,
This is a coffeelake I7 core.
I have used a catalina vanilla images from olarila before for series 300,400 and it worked fine.
I am flshing from windows I don't have access to the file system of the USB drive to change anything.
thanks for your help ;)
u need remap ur usb
i put one generic thing in 11.3 image
7 ports usb2 and 8 ports usb3
change ports and check what work
On 4/28/2021 at 5:03 PM, MaLd0n said:
u need remap ur usb
You are right I tried all ports and it finally booted to the install interface.
But it’s strange cause only USB 3.1 worked and they were disabled in BIOS as adviced for previous installations procedures.
Also I had to unplug GTX 1060 from its pcie slot or I was stuck at « DSMOS has arrived »
I am installing right now ;)
thanks man
temis
Edited by temis01
