Hi Maldon. Can you please help?
BT is missing from SysPrefs (Wi/BT-BCM94360CS). And no audio trough DisplayPort.
You already patched it but I was using it on my other build. I got 2 same builds because I thought it will work on both. Only, this one has no M2 yet.
Thank you very much
Send me Irish-Mans-iMac.zip
Edited by Irish_Man
Gigabyte Z490 - Vision G
Intel  Core i7-10700K
Saphire Radeon Pulse RX 580 4Gb
Corsair Vengeance RGB PRO 32GB (2x16GB) DDR4 3600 C18
Samsung SSD EVO 860 500GB
Corsair HX750 80Plus Platinum
i dont see bt load into usb
check usb cable
audio, is full load
Weird, im using PCIe adapter for WiFi/BT.  WiFi is working but BT is not. I'll pull it out to check connections
