Help! Ethernet Realtek RTL 8111 - Big Sur - Asus B85M-G - Core i5 Haswell - can't install Kexts
Dear MaldON,
Help!
I've tried everything here and over the web, can't find a solution to this problem:
I can't use my Realtek RTL8111 Ethernet. My old solution, Vietnam Tool, does not work on Big Sur. Neither other programs, such as Hackintool or Kexts Installers.
I've tried disabling SIP with "csrutil disable" and "csrutil authenticated-root disable", but still have a messagem "Apple Internal enabled".
I've got various versions of RTL8111 kexts, but can't install none of them.
I've tried everything before ask you.  Can you help me?
Edited by Studio Kinouchi
use kexts in bootloader folder no system folder
  • Thanks 1
MaldON, what folder is that???
I used Clover in all other installations, this is my first time with Open Core...
Thanks!
MaLdOn,
Are you brazilian? Do you speak Portuguese?
Ou seja, você é brasileiro, fala Português?
MaLdOn,
You're the man!
I move the kext to EFI Bootloader (OC) folder and it works!
The newer version (2.4.0) of Realtek RTL8111 kext does not worked. I had to use version 1.1.3.
Thank you very much!!!
